997 : 2004- 65
996 : 1997-2005 35
964 : 1989-1993 1
infrasilver
Fast & Furious
Fast & Furious
2001 Porsche 996 Targa
PostPosted: Tue Jan 22, 2019 4:42 pm    Post subject: A/C climate display LCD screen repair Reply with quote
I have linked this in my "Neglected 996" but thought it best to do a DIY in 996 FAQ's for fixing the LCD screen for the A/C display.
I ordered a new screen kit from Germany and was around £61 and it arrived within a couple of days. This is one of those jobs I have put off for a while as it didn't actually cause any issue with the screen, it just looked unsightly.
Remove the surround and the two torx screws holding the unit in place and pull out, then remove the two power plugs from the rear.
Three screws remove the rear section from the display unit.
Seven screws remove the circuit board from the button section.
Then twisting the tabs straight also removed the screen cage from the circuit board.
Mark up the orientation of the white rear part so it goes back in correctly.
New screen and old screen, the new will have two protection films to remove, then clean the edges where the rubber end pieces fit.
The screen had a lump on one edge so you know which way around this goes back in. I found dropping the screen back into the cage first followed by the backing card then placing the rubber end pieces in afterwards was easiest.
Sorted, should have done this job a while ago as it only took an hour.
PostPosted: Tue Jan 22, 2019 4:50 pm    Post subject: Reply with quote
thumbsup
Good job sir.
PostPosted: Tue Jan 22, 2019 4:53 pm    Post subject: Reply with quote
Agree
