996 Front wheel and tyre size question
Jamesx19
10 Jul 2015
627
Evening
Opinions required of front wheel and tyre sizes on the 996.1 if your able to assist? I assume some of you guys may be able to offer some thoughts and comparisons.....
At the moment the car (a fairly boggo 996.1 C2) has 8" rims on standard ET50 offset and 225/40 18 tyres together with 9mm spacers at the front and 11" rims ET63 at the rear.
My current geo is 1'20" neg front camber with 1'30" rear.
Car handles well, with lots of front end response and little understeer at "normal" road speeds, though will push on if really pressing on into a corner.
I am looking at buying a set of lightweight rims secondhand, but the fronts are in 9" width ET46 which will need 235/40 tyres I'd have thought?
Opinions and knowledge sought:
What differences in front end bite / traction and handling with the wider rims and tyres?
Will there be less feel through the steering?
Will the car be a bit "traction heavy" and less mobile? One of the things I enjoy is the feedback and feeling of the cars grip ebbing and flowing at sane road speeds...
Car is only road use. Many thanks
235 profile is the minimum fit to a 9" rim, so the tyre will look stretched a bit, 245 or 255 is the ideal size for 9"
Are these still an 18 inch rim or are you going to 19? If going up to 19 you need 235/35
9" rim 46 offset will come out a bit more than your previous with the spacer, like 8mm or so : turn full lock and see how much clearance you have to the wheel arch plastics on current rims and imagine another centimeter..
May I ask how on earth do you know these numbers? Is there a magic chart somewhere that shows the matrix?! :eh!:
Assuming your running 285 at the rear?
With 225 x 285 the car will understeer, period.
More tyre at the front helps reduce this, and brings the car a little more towards neutral, albeit a very little bit! - you can fit 235 on an 8" rim.
9" is doable on the front, but you will get rubbing on the arch liners, unless your tracking the car and planning on 245's your running extra wheel width and weight for no benefit.
Your proposed 9" wide front wheels may be light weight, but they're still two inches too wide. I've run a 235 tyre on the front of my 996.1 and it (just) rubbed on the wheel arch liner. 245 will definitely rub. My reason for going to 235 was because my car understeered badly. It turned out that the cause was too soft rear springs and dampers, and poor geometry settings. The tyres had a much smaller influence on the handling balance than you would expect.
If you want a nice driving 996 for the road then you should be looking at less wheel rather than more. After a lot of experimentation, I run 255/17 on the rear and 205/17 on the front. I'll be going up 20 215 on the front as and when I can be 4rsed. You have a colossal amount of camber and tyre on your rear and if you really appreciate a car that talks to you about grip limits then you need to reduce your tyre width and reduce your rear camber. With more upright rear tyres you'll find you have more predicatable and better access to oversteer, which is where the fun is.
As my car continues to get lighter, I may well go to 245 rears. The obsession with stupidly wide rear tyres on Porsches needs to stop.
Yes, there is... See below.
For rolling radius calculator and poke see will they fit. Com
But essentially the calculation for poke you can do in your head, the lower the offset et number, the further out the wheel pokes out of the arch. A spacer reduces offset and makes wheel poke more.
Current offset 50, minus 9 for your spacer makes 41.
New wheel is 9in vs 8in so 26mm wider, but that's halved as its equal either side of the hub.
New offset is 46 (without the spacer), but 9in wheel so sticks out 13mm more for the wider wheel, but the previous effective offset was 41 so stuck out 5mm more, 13 minus 5 makes 8mm more poke with the wider wheel when dropping the spacer and putting on the 9in wheel.
Many thanks for all the responses.
Together you have coalesced some of my suspicions and concerns.
I have I confess, been trying to make a case for them on the basis that they are financially viable rather than dynamically the best option.
Asterix-the-gaul is bang on with the maths and Crash7 / Martin996rsr many thanks for your experiences. That was the sort on information I was after.
The other point that Im not totally convinced by is how much difference a lighter wheel will make in the grand scheme of things. I'll go back to thinking about Fuchs again, but ultimately I'm looking at 3.2kgs off each of the fronts and 4.8 kg off each of the rears.
Albeit the Fuchs allow me to fit smaller rear tyres which I feel he right to say may provide a more involving road driving experience.
Im currently 225/40 fronts and 295/30 rear which as Crash7 points out will always result in understeer, and I suspect doesn't allow me to bring the rear into play with a lift of the throttle as steering lock is applied. Well not at sane road speeds anyway!
Thanks chaps.
For interest the wheels Im looking at came off a 993 turbo and are 9x18 et46 and 11 x 18 et59. I think the rears may stick out a bit too much for my narrow body car and would need 15mm spacers for a turbo body.
Might be good track wheels though as reputed to be 8kgs front and under 9 kg rear.
had a similar weight reduction going from solid spoke turbo twists to the hallowed hollowspoke twists on my 993. Made naff all difference. Dropping to a 265 rear was noticeable as the rear could then slide a bit easier.remember the tyres weigh nearly as much as the wheels so bigger tyres add weight
The quoted 8 and 9 kg are really light for that size wheels most are at least 1-2 kg heavier. Not that you would be able to tell without scales
.http://www.944racing.de/wheelweights.php[/i]
As has been said in another thread on here: 'It's the sum of incremental changes, innit..' i.e. Lighter wheels will have a small but positive effect, but when combined with many other small changes the car can become dramatically better.
I reckon the best choice if you're just going to limit your development of your car to a wheel and tyre choice, then choose a wheel you like the look of that allows you to fit a tyre size that will give the driving experience you seek. An 11" wide rear rim will limit you to a minimum of a 285 section tyre, something which we know will still give you understeer. If you can find a set of Boxster Sport Classics then that would be a great choice as they look great, are 18", so will look nice in the arch, and they are the right width to be able to put sensible tyres on that will allow you to adjust in some corners with the throttle if you want (given appropriate suspension geometry settings).
Some good points both.
I'm chipping away at the weight. I know it's not to all tastes, but I'm happy with the compromises so far;
Rear wiper delete
Air con compressor delete
Rear seats and belts gone.
Maybe 20 -23kgs overall. Minus 16kgs wheels, 20 kgs lighter seats minus 15 kgs battery etc. Might get it down to 1250kgs on narrower tyre.
There are other areas I'm not so keen on changing I.e.
Sound deadening or removing the spare wheel etc.
May leave big ticket items like wheels a bit longer based on how much effect each mod has on the car....
All 996's will inherently understeer, its a quirk, you can eliminate a lot through setup etc, but in essence you need to adapt your driving style to live with it as oppose to trying to engineer it all out.
I run with 235 / 285 on 8" & 10" which works for me, I may eventually try 245's on the front but I will need adjustable thrust arms prior to allow for correct caster adjustment and to stop the tyres rubbing the arch liners.
996 Cup Cars run 9 & 11" most PCGB guys run 8 & 10, with with appropriate width slicks.
The front tyres also take care of a lot of the braking if your running a decent about of camber when the car is in a straight line you have a reduced contact patch a wider profile will give you a little back.
In regards to weight, the car will always weight more than you think - If you get your car to 1300Kg excluding fuel you will have done well.
I was expecting mine to be circa 1275, C2, no-sunroof, manual, as I have gone after pretty much everything easily achievable, partial stripped interior, buckets, light weight battery, giro discs, coilovers, LWFW, GRP bonnet etc etc with the exception of replacing panels for carbon and wheels. - I have a set of OZ that will drop me closer to 1275 but I like the standard wheels. At present mine weights 1297kg, no fuel.
Chris at CoG mentioned that everyone thinks their car will be lighter than it is.
In my experience you won't get near 1250 unless you invest significantly in replacing parts, carbon wings, plastic windows etc etc
Its also easier to strip weight from the front of the car, spare, tool kit, CD Player, light weight battery etc, but this only serves to compound the understeer issue.
I find the car is faster, with half a tank of fuel than with 1/8, so although fuels adds roughly 1Kg per Litre, the extra weight over the front wheels helps with traction.
I wouldn't get hug up on weight or tyre width, do what you like and works for you.
I'd really like to try my 17's back to back with my 18's over the same road/track, given the nature of the conversation in this thread (and many others) about the car being more engaging on 17's.
I'm sure it's true, but I'm unsure that I can actually detect it!
That's really good interesting info Crash7. And valuable in the sense that is your experience rather than something someone has heard from a third party and regurgitated.
I do wonder at how much this stuff effects the overall experience of the original car. It's still a 911 996 with the same weight distribution and ballpark power/weight, etc.
When I carry a 85kg passenger, I can detect the car is slightly slower and less responsive but not massively different overall.
How often do I use full throttle? Twice in the last month of driving, for about 4 seconds total before I was doing some crazy speed and prudence dictated a coast down to the next corner.
Modded C2's have been compared in magazine articles to a GT3 of the same vintage and whatever the C2 has had done or spent on it, the article always concludes it's nice, but not as good/fun/focused as a GT3.
Though as Martin996rsr says, a host of small changes can add up to a different compromise and overall experience. Biggest difference so far has been the current geo settings.
Food for thought I feel.
Biggest issue with 17" rims? I don't like the looks. How shallow? Yes I know sorry!. Dynamics and driving feel are all well and good, but it needs to look the part right?
Some sound opinions thanks
Reducing weight is always going to be good but as said depends on where from.
I suppose the thing here is the feel through the wheel and how the cars is over normal UK roads i.e. Unsprung mass must have a difference on how the car feels over bumpy roads. Is that not one of the big things to us when driving these cars?
I've had lightweight OZ, STD wheel and loads of aftermarket and I have noticed a difference albeit not massive.
Currently have fairly light wheels with reduced width rear but running 225 and 265 tyres and it feels like a good balance. Is increasing front track not another way to help regards the understeer?
Hi Coullstar,
Sorry only just seen your post.
Totally agree. Most fun roads round where I live are B roads, but a lot of C and Unclassified too. As you can imagine the road surfaces are the same as everywhere else in post recession UK, bumpy potholed and a multitude of surfaces.
I'm very chuffed indeed with the Bilstein B8 dampers and H&R springs. They have gotten better with a few thousand miles on them now. The car never "bottoms out" or scrapes he road, and rarely gets to smack the bumpstops with any great force. In addition the ride, whilst firm, rounds off the bumps without feeling crashy.
It results in fast comfortable progress over these type of roads, without having to back off and make concessions for less than favorable road conditions. If lighter wheels made this better, which they should (?) then Id be happy. As long as I like the looks though!
265/35 rears seem to be favoured by those that have responded to this thread. Not much difference in weight between those and 285/30's.
Cast 17" wheels seem very much the same weights as forged 18" ones, and 17" tyres weigh slightly less again. Just can't help being a bit superficial though!
124,588
1,441,803
49,015
robertcloftus
