997 : 2004- 73
Boxster : 1997- 18
Cayman : 2005- 20
Britince
PostPosted: Sun Nov 04, 2018 9:42 am    Post subject: 997.2 led rear light repair Reply with quote
My rear light has failed. I’m looking at buying a used one which has a chipped fascia. Should I be able to transfer the working internals from this into my undamaged casing?
Magic919
PostPosted: Sun Nov 04, 2018 4:20 pm    Post subject: Reply with quote
Probably not.
997.2 C2S PDK
997.2 C4S PDK
-- 997 --
PostPosted: Sun Nov 04, 2018 4:20 pm    Post subject: Re: 997.2 led rear light repair Reply with quote
You can only change the electronic boards which i have 2 off if thats what you need as i took some out of an old cluster set i had! but to change the LED lights no!! You have to crack plastic and most likely damage to take the lights out as,
Best bet is to buy a new set from porsche, they are cheap now!!
If its the circuit boards you need then i have...
J
neil_911
PostPosted: Sun Nov 04, 2018 4:26 pm    Post subject: Reply with quote
You can remove the reverse light cluster part, and as mentioned the circuit boards. But i tried the LED panel and got so far but its plastic welded in if i remember correctly.
How "cheap" are they from Porsche now? Were plus £300 when i looked last year.
Fixed mine with some clear paint protection film and they haven't fogged up since.
Basalt Black 997.2 C2S PDK - for the weekends
Mercedes S500 5.0L V8 - for the commute
Britince
PostPosted: Sun Nov 04, 2018 8:03 pm    Post subject: Light circuit board Reply with quote
Thanks guys.
Suzuka- thanks for the offer of the circuit board. Would love to try to see if this would fix the problem rather than buy a new unit (about £490 from Porsche)
Please let me know the best way to arrange this.
Thanks again,
Martin
