997 : 2004- 73
Boxster : 1997- 18
Cayman : 2005- 20
JayG60
PostPosted: Sat Nov 03, 2018 2:42 pm    Post subject: Weaknesses of a 997 other than the engine.... Reply with quote
As I am currently in the process of starting an LS3 swap into my 997 3.8s (“Project half a cup” thread) which will eliminate all the weaknesses of the M97 engine. I also want to know what other aspects of the 997.1 people think could be improved,
One I will be addressing is cooling, so I will add a third rad and upgrade the other two, I will also be adding Porsche cup electric steering pump, adjustable bushes and some aero bits, as well.
Thoughts....
Jay
Shanghai
PostPosted: Sat Nov 03, 2018 2:57 pm    Post subject: Reply with quote
Going off at a tangent on the coolant element has anybody ever used waterless coolant with its enhanced cooling properties? Which seems ideal on a 911 where cooling is clearly a big issue?
991 C2S X51 powerkit PDK in racing yellow, PCCB, PDCC, PSE, Sports design kit, ducktail.
EX 997.2 Carrera 4S PDK
EX 997.2 Carrera S PDK
EX 997 C2 gen 2 PDK
EX 993 Targa
EX 993 Carrera 4 manual
EX 996 3.4 Cabriolet
maldren
PostPosted: Sat Nov 03, 2018 5:32 pm    Post subject: Reply with quote
There are threads here somewhere. IIRC people recon it has issues. Hartech had interesting comments, try a search.
Interestingly magazines have fitted it but not provided long term assessments.
Oh and it's expensive, you need to factor in the flushing procedure....
Mike
Clanky
2007 Porsche 997 Turbo
PostPosted: Sat Nov 03, 2018 11:28 pm    Post subject: Reply with quote
From what I've read, the 3rd rad isn't really needed unless it running in a hot climate.
The cooling problem is caused by the thermostat being on the return line to the engine on the original M96/97 engines.
I for one cant understand the reason for it being fitted there at all.
Assuming the LS3 has the stat on the water pump side it shouldn't be an issue.
996 C4s (Gone)
997 Turbo
S3 Daily Driver
msaif996
PostPosted: Sun Nov 04, 2018 3:25 am    Post subject: Reply with quote
Not too sure about the hot climate, I have a MY02 996 3.6 Carrera 6Mt 80k Miles completely standard and I regularly drive it in the summer when temperatures reach 55c. No issues whatsoever.
