Key/Remote issue
iceboy
Nurburgring
18 Apr 2013
387
Hi All,
Just got back from a work trip and with the blue skies and sunshine, I thought I'd take the Turbo S for a spin.
The car has been on a C-Tek charger for approx 2 weeks and I opened the door with the key as it usually goes to sleep.....anyway, when I went to start the car everything lit up as usual but when I went to crank, nothing. So I turn the key back to the first position and tried again and it started fine.
I have just got back from a beautiful drive through the Berkshire/Buckinghamshire boarders !!
I put the car in the garage and when I pressed the key fob nothing, I tried a few time but it was dead.
So I have locked the car with the car in the door.
Could this be a battery issue? Could the starting issue also be connected?
It is going to Nine Excellence next week but thought I would scrub up on my knowledge.
IceBoy :thumb:
Hi Iceboy, am sure someone more knowledgeable will be along shortly.....in the meantime, my thoughts....
The car going to sleep (not responding to the key) is standard, if its left to sit for a while (week or so)
If after failing to start, its then able to crank the engine to start the car, it doesn't sound like a battery issue (doubly so, as you are using a Ctek to keep it charged). As the second time you try there would be even less charge than the initial try.....
I don't think there is any connection between locking/unlocking the car and the ability to start the car. The starting issue sounds like an immobiliser issue. As I understand it, the unlocking/locking key fob function is actually unrelated to the immobiliser function (they are done by completely separate items, both within the key-fob.
Couple of things it could be ..
Having to try and start it twice could be ..
1/ Coincidence and a 1 off
2/ Faulty ignition lock
3/ Startermotor solinoid is starting to play up.
Fob not working ..
1/ Fob needs replaceing as its died
2/ Faulty ignition lock as it thinks the key is still inserted .. pretty dam rare though .
Door unlock is done by the fob transmiting a signal , car starting is done by a chip / pill in the fob that the ignition lock decoder reads so as king4 said .. 2 seperate systems.
Anyways .. 9 Exc certainly dont need any help from me !
Hi there I'm no mechanic but I had a similar experience with my Cayman last year.
No you may not have this on your car but it turned out to be a switch that when you dip the clutch it is supposed to trigger and let the car start.
Mine was not triggering all the time and I was felt pumping the clutch and trying again.
Just a suggestion:dont know:
124,554
1,441,463
48,967
Max V
