964 : 1989-1993 5
Boxster : 1997- 19
Cayenne : 2003- 3
Macan : 2014- 1
Kbald
PostPosted: Thu Nov 01, 2018 7:24 pm    Post subject: C4 fuel filter change advice Reply with quote
Hi i am chaning the fuel filter on my c4 and its by the coolant expansion tank and from reading up this should just clip on and off and make it easy to change. I cant for the life of me see the clip though and all thats there is a jubilee clip holding it on.
Am i missing something or were some filters just jubilee clipped on and some had the clip on method? From watching a you tube video it looks a real pain to do if it doesnt clip on and off. Has anyone done it and can provide any pimters? Thanks
2000 Carrera C4 Cabrio Tiptronic
PostPosted: Thu Nov 01, 2018 7:36 pm    Post subject: Reply with quote
You undo the jubilee clip then slide it with the filter and it will detach from the coolant tank .. once off then all will become clear .
Basically the jubilee clip goes over a bracket on the tank .. when you undo it you slide it i think towards you but might be away from you and it will detatch .. you then wiggle it out .
Not sure this helps much as i dont remember it being as hard as he seems to make out .. but ive not done one in a while .
https://www.youtube.com/watch?v=e6ootEumHAc
 Filesize:  36.05 KB
 Viewed:  528 Time(s)
Kbald
PostPosted: Fri Nov 02, 2018 7:02 am    Post subject: Reply with quote
Thats the video i watched and he make it look like a right faff. Cant be that hard. Will get plenty of rags in there and plug the pipe with a golf tee when removed and use the cap for the new one on the old while removing to prevent too much spillage i think. Bit of giggling and it should be fine. Must just be the turbos that have the clip on them then as thats the guide i found.
Thanks Demort Thumb
