996 : 1997-2005 43
Boxster : 1997- 13
Cayman : 2005- 12
Macan : 2014- 0
peterzoom
2001 Porsche 996 Carrera 4
PostPosted: Thu Nov 01, 2018 12:02 pm    Post subject: Confused about Beru ignition coils Reply with quote
Can anyone explain the difference between the ZS031 and the ZS177 coil packs please? I've asked automotive, euro and CP4LESS but no one seems to know any details other than that they are both suitable. I'd like to understand if one is more suitable or is improved specification before purchasing
Chris_in_the_UK
Estoril
PostPosted: Thu Nov 01, 2018 12:31 pm    Post subject: Reply with quote
Beru list the ZS177 for your car, looks as though this is the replacement for the ZS031.
2006 Cayman S PCCB's
peterzoom
PostPosted: Thu Nov 01, 2018 12:35 pm    Post subject: Reply with quote
I see both listed on the autodoc site as both being suitable but one has an image without mounting bolts. When I asked through their helpdesk I was told that either would suit but they didn't know what the variances were between the two Question
Chris_in_the_UK
Estoril
PostPosted: Thu Nov 01, 2018 12:38 pm    Post subject: Reply with quote
Unlikely they would know - the ZS031 is shown as no longer available on Beru's website, Autodoc and others will probably have some old stock alongside the replacement coil.
peterzoom
PostPosted: Thu Nov 01, 2018 12:45 pm    Post subject: Reply with quote
Yes that would make sense if the part numbers are sequential, with the newest version having the higher number. Also might explain why there is a price gap between them also.
alex yates
PostPosted: Thu Nov 01, 2018 1:17 pm    Post subject: Reply with quote
Isn't the counter bores different on the newer ones ans are further out, thus needing lomger cap head bolts. Sure there's a thread about it on here.
alex yates
PostPosted: Thu Nov 01, 2018 1:21 pm    Post subject: Reply with quote
Here: http://911uk.com/viewtopic.php?t=111716
maldren
PostPosted: Thu Nov 01, 2018 4:43 pm    Post subject: Reply with quote
These are my original and replacement coil packs, all Beru. The bolts came with the new coil packs and (hopefully) the new packs will be less prone to crack.
You'll need torx sockets.
Mike
 Filesize:  254.11 KB
 Viewed:  690 Time(s)
peterzoom
PostPosted: Thu Nov 01, 2018 5:13 pm    Post subject: Reply with quote
Thanks for putting up the before and after pics, very useful. The new ones look exactly like the the image on autodoc that shows the ZS177 with the bolts displayed.
So I guess the smart move is to check that when one is purchasing coil packs that the later ZS177 model is the one to go for at this time.
Good, that really helped, thanks everyone Thumb
alex yates
PostPosted: Thu Nov 01, 2018 5:35 pm    Post subject: Reply with quote
I'd prefer the older ones, bet they're miles easier to fit.
PostPosted: Thu Nov 01, 2018 8:03 pm    Post subject: Reply with quote
Indeed the early ones are the easiest to fit .. the later ones are a lot fatter and on some models dont fit .
As far as im aware the older ones are either no longer avaiable or in Very short supply.
New coils come with longer bolts in the box but male torx head .. at least everyone ive fitted has .
Porsche changed the design due to the early ones cracking .. which was actually a fault Beru had corrected on their aftermarket coils years ago .
Porsche say you have to replace all six if only one needs doing .. Bull s$%t .. do as many or as few as you want .
JTT
PostPosted: Thu Nov 01, 2018 8:28 pm    Post subject: Reply with quote
I used the updated ones on mine when I replaced them last winter. No harder to install other than adding a washer to space the heat shield off the taller coil pack.
