997 : 2004- 76
Boxster : 1997- 16
Cayman : 2005- 18
Do you have any wind noise at 60+ MPH?
None at all
87%
 87%  [ 7 ]
Some from the centre left bottom
0%
 0%  [ 0 ]
Some from the bottom (all / or somewhere)
12%
 12%  [ 1 ]
Total Votes : 8
v6matt
PostPosted: Mon Nov 05, 2018 1:52 pm    Post subject: Reply with quote
Right an update on this one, after masking taping the car as per above....silence !
I was also in the passenger seat this time and its clearly coming from the top corner of the passenger windscreen.
This now clearly points to the recent windscreen fitting.
Looking closely, I already knew that the windscreen rubber was slightly lower at the top than factory (due to original sit line) but I bet it is actually penetrating at that upper left hand side where you can see the slight gap against the painted surface.
So given I dont think there is a simple fix/wider rubber trim, then I need to look at getting it re-fitted or see if a little spec of black silicone doesnt look too ungainly until a stone flicks up and kills the screen.
2008 Carrera 4 - Gen 1 997
 Filesize:  90.18 KB
 Viewed:  328 Time(s)
Goto page Previous  1, 2
Page 2 of 2
