997 : 2004- 73
Boxster : 1997- 18
Cayman : 2005- 20
Do you have any wind noise at 60+ MPH?
None at all
87%
 87%  [ 7 ]
Some from the centre left bottom
0%
 0%  [ 0 ]
Some from the bottom (all / or somewhere)
12%
 12%  [ 1 ]
Total Votes : 8
v6matt
PostPosted: Sun Oct 28, 2018 5:16 pm    Post subject: Windscreen/Wiper wind noise? - Do you have any? Reply with quote
In my continuing confusion having bought a 911 a few weeks ago, I still can't work out whether the noise I hear is normal or not.
Basically at 60+ MPH, I seem to getting some noise from the centre/left of the windscreen, it sounds like its coming from near the bottom almost like static from the speakers or some erroneous air coming through the demister vents.
I just tried masking off the passenger side of the screen and it made no difference, and I am wondering if 911's just make more noise that average at speed and perhaps its just air hitting the wiper blades?
Or it could be the windscreen but for it to be coming from the bottom and with a tightly fitted scuttle panel...it just doesn't make sense.
Anyway your input on the noise would be great, or other suggestions to try.
2008 Carrera 4 - Gen 1 997
pzero
PostPosted: Sun Oct 28, 2018 5:23 pm    Post subject: Reply with quote
A less than satisfactory fit to a replacement windscreen?
I don't know if that's what is causing the noise in your car but I have experienced noise coming from the windscreen edge when going over certain speeds, and that followed a windscreen replacement. After a refit the noise disappeared.
991.1 Carrera GTS
PostPosted: Sun Oct 28, 2018 5:24 pm    Post subject: Reply with quote
Just a thought but remove the inside cover for the wing mirror and make sure the wiring plug doesnt have any gaps around it that could let air through .. wind noise .
Cover pulls out at the base BUT lifts upwards at the top.
v6matt
PostPosted: Sun Oct 28, 2018 5:39 pm    Post subject: Reply with quote
Thats the odd thing with mine, it doesnt seem to be from the top or edge and I taped off the passenger side windscreen with masking tape including the top to reduce wind entry but with no impact, it seems to be from the lower part of the windscreen near the vents or opposite side of the wiper blades....which is raising my suspicion that it may not be the windscreen refit. Also with nothing to reference I may be in overthinking mode Wink
v6matt
PostPosted: Sun Oct 28, 2018 5:40 pm    Post subject: Reply with quote
Thanks I will check this thumbsup, as it does sound like any windnoise from the from the areas I mentioned at national speeds is unusual.
This is how the car looked just before hitting the motorway earlier Grin
Masking adventures
 Filesize:  1.21 MB
 Viewed:  1326 Time(s)
Magic919
PostPosted: Sun Oct 28, 2018 7:24 pm    Post subject: Reply with quote
Might be the non-standard wipers.
997.2 C2S PDK
997.2 C4S PDK
v6matt
PostPosted: Sun Oct 28, 2018 7:31 pm    Post subject: Reply with quote
I swamped them back to standard old style ones, no difference Sad
v6matt
PostPosted: Sun Oct 28, 2018 7:46 pm    Post subject: Reply with quote
You raise a good point though, my passenger wiper looks too low based upon some low res pictures I can see elsewhere.
Could someone take a photo of their wiper position, I think it should be slightly higher and above the black tint.... a bit more like this (the position towards left of picture as thats a LHD) https://www.suncoastparts.com/mm5/graphics/00000002/porsche%20wiper%20cowel%20cowl%20panel%20wiper%20boxster%20cayman%20carrera%20911%20997%20987.jpg
PostPosted: Sun Oct 28, 2018 8:12 pm    Post subject: Reply with quote
Just a thought but make sure your scuttle if fitted tight , they do sometimes warp in the heat and that may be causing some air turbulance that you can hear. also try opening and closing the air recirculation button see it that makes any difference. Thumb
PostPosted: Sun Oct 28, 2018 8:15 pm    Post subject: Reply with quote
check the size wipers you have as so many people fit both the same size as its cheaper as a pack of two but one is an inch longer than the other and as you say should not be in contact with the scuttle lip and as the pic more inlinewith the black screen border
PostPosted: Sun Oct 28, 2018 8:21 pm    Post subject: Reply with quote
Put masking tape in the shown areas .. if you have the noise after this then its not wind noise .
 Filesize:  1.01 MB
 Viewed:  1254 Time(s)
v6matt
PostPosted: Sun Oct 28, 2018 8:31 pm    Post subject: Reply with quote
Thanks, they are definitely different. 22 and 21 if I remember rightly. I have also already checked the scuttle panel and its on solid with good rubber contact at the top.
v6matt
PostPosted: Sun Oct 28, 2018 8:33 pm    Post subject: Reply with quote
Thanks, I will do that on my next motorway run between junctions/service stations.
I specifically went on the hunt for a 70 zone today and took me over an hour return Grin, good excuse to play but not for every test.
I also have an air bed pump which I will use to blow around all the crevices and see if I can re-create it. Damn niggly things.
v6matt
PostPosted: Mon Oct 29, 2018 1:10 pm    Post subject: Reply with quote
I did this quickly this morning before leaving for work.
The only thing I noticed was a slight lip at the very top. Does this look unusual i.e should seal/cover it?
Also interestingly, it looks like someone has exactly the same symptoms http://www.911uk.com/viewtopic.php?p=619161 I have messaged them to see if they found a cure.
Also back near the car again, I also noticed using that threads idea about water on a seal. The top of the passenger window did have a weaker seal than the drivers side, so my wifes hair band is doing stirling work of sitting in there to push out the seal. Will see if this helps as well.
Also noticed the seal around the boot area was 'open' on the drivers side, so will check this when home as I suspect one of the plastic supports has gone walkabout and is not proping up the frunk trim into the rubber.
My theory here is that wind is entering here...creating noise somewhere further down and this is audible via the pollen filter opening and hence why I keep thinking its 'excess noise through the passenger top dash vent'
 Filesize:  1.16 MB
 Viewed:  1172 Time(s)
 Filesize:  295.65 KB
PostPosted: Mon Oct 29, 2018 7:17 pm    Post subject: Reply with quote
From memory they should have tape around the wiring plug .. use a bit of gaffer tape please to make a seal around that plug and out to the bodywork just in case .. 5 mins and a pair of scissors Smile
EDIT ..
If you press the recirc button it closes the flap in the pollen filter houseing there by eliminateing and air going through there .
v6matt
PostPosted: Mon Oct 29, 2018 8:21 pm    Post subject: Reply with quote
EDIT ..
Worth a go!, I did put some masking tape around that gap but can't hurt to go around it some more. It could be the ones you have seen/done have been taped to prevent the noise as it seems they normally come without.
Also I checked the frunk plastics this evening, turns out I am missing the very top left hand screw fixing bracket which is why the trim was sinking. That and a new screw on the way from Porsche for the grand total of £3.50 delivered !
Re: Recirc - Damn I think I have already tried that, worth another go!
https://cimg1.ibsrv.net/cimg/www.rennlist.com/470x469_85/381/step1b-2-1--62381.jpg
If all else fails, then its back to the windscreen.
PostPosted: Mon Oct 29, 2018 8:40 pm    Post subject: Reply with quote
You are doing the right thing .. i also mask trims with tape to try and find a wind noise .. if its all masked and there is still a noise then its not wind !
I am wondering .. on 996 we used to fit tape under the screen rubber to stop creaks .. maybe Dont know
Not seen that on a 997 though .
What you need to do .. which obviously you cant as your too far away but is come grab me in Brighton so i can have a listen Very Happy
Why is it almost every person here lives so far away from me .. sigh.
I need to move further North i feel .. which as the wife wont follow might be a good thing Very Happy
v6matt
PostPosted: Mon Oct 29, 2018 8:50 pm    Post subject: Reply with quote
Thanks deMort!
You have been VERY helpful, I would absolutely drop in if local.
I will probably have to take it back to the specialist I had it serviced at, when I head back that way/nearby if I don't have any joy with it.
However I suspect Sunday is the day to test it, as I am finally heading onto a motorway then. Not sure what the wife will thing of a masked off 911 ! Mr. Green
Robertb
2002 Porsche 996 Carrera 4S
PostPosted: Mon Oct 29, 2018 9:02 pm    Post subject: Reply with quote
Have you checked the screen and surround for any objects... I had a strange wind noise from our Audi A8 which was driving me mad. In the end I spotted a tiny insect wing that was embedded in the surround rubber. Pulled it out and all was quiet! Just as you describe though, a static-y sort of noise.
v6matt
PostPosted: Mon Oct 29, 2018 9:07 pm    Post subject: Reply with quote
I have, nothing visible Sad
