997 : 2004- 73
Boxster : 1997- 18
Cayman : 2005- 20
Milo72
PostPosted: Fri Oct 26, 2018 2:09 pm    Post subject: A grill with a difference... Reply with quote
Fitted a set of grills today...
What started as a quick grill fitting turned into a bumper off, radiator clean up and a general tidy up. I also took the opportunity to add a little colour to the black surrounds of each opening, what do you think?
Personally really pleased at how it’s come out, matches the callipers perfectly.
997.1 C2S Cab Tip.
 Filesize:  1.98 MB
 Viewed:  1896 Time(s)
Thefinn
PostPosted: Fri Oct 26, 2018 2:24 pm    Post subject: Reply with quote
looks good mate what grills are they Zunsport's?
997.1 C4S CAB
Milo72
PostPosted: Fri Oct 26, 2018 2:29 pm    Post subject: Reply with quote
Yes they are... got them with the 20% discount code kindly shared in here
997.1 C2S Cab Tip.
benbuhagiar
2008 Porsche 997 Carrera 2
PostPosted: Fri Oct 26, 2018 4:09 pm    Post subject: Reply with quote
They look great. Have a got a picture showing the whole car please? Looking to get some myself.
997.2 Carrera PDK
Milo72
PostPosted: Fri Oct 26, 2018 5:15 pm    Post subject: Reply with quote
Here you go.... also a 20% discount code from the official site, saved me over £40.... PT022016
997.1 C2S Cab Tip.
 Filesize:  941.12 KB
 Viewed:  1804 Time(s)
PostPosted: Fri Oct 26, 2018 10:09 pm    Post subject: Reply with quote
Milo tell me about the red trim what you used how it fitted etc. Thumb
Milo72
PostPosted: Fri Oct 26, 2018 11:12 pm    Post subject: Reply with quote
Behind the two side and centre openings there are black plastic trim pieces attached to the bumper (as per picture below) After taking the bumper off I simply removed these, cleaned and degreased them, sprayed with plastic primer and gave them the once over with post office red paint and put them back in. I think it adds a touch of colour but in quite a subtle way and ties in well with the callipers.
997.1 C2S Cab Tip.
 Filesize:  258.87 KB
 Viewed:  1687 Time(s)
BHZ661
PostPosted: Sat Oct 27, 2018 7:07 am    Post subject: Reply with quote
Looks good as you said ties in with calipers
PostPosted: Sat Oct 27, 2018 10:46 am    Post subject: Reply with quote
Ah , I though it was tape od some sort you actually sprayed the frames red , nice . agreed a nice subtle mod and a new one on me Thumb Thumb Thumb
NLW73
PostPosted: Sat Oct 27, 2018 3:05 pm    Post subject: Reply with quote
looks good Milo
how big are the gaps between the holes? 1cm x 1cm?
if you wanted to do a DIY job on this what material should you be getting? sth that is satin black and not too big gaps and then cut to fit once bumper is off.
DIY shop?
997 C2s Schwarz
Milo72
PostPosted: Sat Oct 27, 2018 4:25 pm    Post subject: Reply with quote
NLW73 wrote:
looks good Milo
DIY shop?
The holes are probably smaller than 1cm x 1cm. I looked at making something myself as there are sheets of similar material in ebay, but i’m glad I didn’t. The Zunsport’s are a perfect fit and look great, i’m not sure I could have made something myself look as good.
The kit was about £180 after discount and well worth it in my opinion.
997.1 C2S Cab Tip.
Magic919
PostPosted: Sat Oct 27, 2018 5:00 pm    Post subject: Reply with quote
These look ok on the Gen 1, but I’m still not convinced about the Gen 2 equivalent. I bought some and doubt I’ll ever fit them.
997.2 C2S PDK
997.2 C4S PDK
NLW73
PostPosted: Sat Oct 27, 2018 5:08 pm    Post subject: Reply with quote
Nice one who did you get the zunsport kit from? Design 911?
997 C2s Schwarz
Milo72
PostPosted: Sat Oct 27, 2018 6:10 pm    Post subject: Reply with quote
No direct from Zunsport.... I had the 20% off code above which made them cheaper than D911
997.1 C2S Cab Tip.
NLW73
PostPosted: Sat Oct 27, 2018 6:52 pm    Post subject: Reply with quote
997 C2s Schwarz
Magic919
PostPosted: Sat Oct 27, 2018 6:55 pm    Post subject: Reply with quote
This could take a while.
997.2 C2S PDK
997.2 C4S PDK
hedgehogsdad
PostPosted: Mon Oct 29, 2018 12:24 pm    Post subject: Reply with quote
I also think that they don't look right on the 997 Turbo as they sit in front of the "fins". Has anyone with a Turbo ever fitted the Rennline kit https://www.design911.co.uk/fu/prod128377/Rennline--Front-Bumper-Wire-Mesh-Grill-Kit-Porsche-997-Turbo-05-09/ and if so, do they sit behind the bumper (and fins)?
2006 997 Turbo
2003 996 Turbo
2006 Cayenne
1999 996 C2
1990 964 C2 Targa
1980 SC
Magic919
PostPosted: Mon Oct 29, 2018 1:49 pm    Post subject: Reply with quote
The Rennline kits mention bumper removal, which sounds promising. This thread show some pics https://www.6speedonline.com/forums/997/272590-new-mod-rennline-front-grill.html
997.2 C2S PDK
997.2 C4S PDK
hedgehogsdad
PostPosted: Tue Oct 30, 2018 10:10 am    Post subject: Reply with quote
I thought that, but then the pics seem to be of an N/A car rather than a Turbo?
2006 997 Turbo
2003 996 Turbo
2006 Cayenne
1999 996 C2
1990 964 C2 Targa
1980 SC
James M-S
2009 Porsche 997 Carrera 2
PostPosted: Tue Oct 30, 2018 1:27 pm    Post subject: Reply with quote
DW performance near Northampton have a solution that sits behind the grills.
