996 : 1997-2005 43
Boxster : 1997- 13
Cayman : 2005- 12
Macan : 2014- 0
Grey996
PostPosted: Fri Oct 26, 2018 12:09 pm    Post subject: Spyderperformance coffin arms and tuning forks, any issues? Reply with quote
Fitted these at each corner but the guys at the alignment place can’t get it to align at all and have said it must be due to these non genuine parts.
The research I did before was all positive but has anyone had any issues?
2002 Porsche 996 C2
911munKy
PostPosted: Fri Oct 26, 2018 1:01 pm    Post subject: Reply with quote
How far out is the alignment, is it just the Camber that is out when the toe is dialled in?
A few years ago some folk did have problems with a batch of Meyle coffin arms and Camber at the rear but not heard of any issues recently.
Also has your car been lowered, if so by how much?
It will be possible to sort but some extra parts are probably required.
2000 C2 996
Grey996
PostPosted: Fri Oct 26, 2018 9:43 pm    Post subject: Reply with quote
Not sure about numbers but apparently they couldn't get it anywhere near at the back. It's been lowered 30 mm and they're using the X74 settings.
Hopefully all sorted, apparently a specific order to the settings is needed. SP were great and talked the alignment technician through the sequence. It's gone over to Monday but should be fine.
2002 Porsche 996 C2
maldren
PostPosted: Sat Oct 27, 2018 7:50 am    Post subject: Reply with quote
I had mine fitted by CG with Ohlins and I had no issues whatsoever, good parts at a good price.
Mike
Grey996
PostPosted: Sat Oct 27, 2018 11:16 am    Post subject: Reply with quote
Thanks Mike
2002 Porsche 996 C2
