964 : 1989-1993 5
Boxster : 1997- 19
Cayenne : 2003- 3
Macan : 2014- 1
RossJ
PostPosted: Thu Oct 25, 2018 7:11 pm    Post subject: OPC Oil Reply with quote
Hey All,
Newbie to the forum and hoping for a little guidance if possible.
I've been having the issue described in the following thread with my 06 plate C4S, which has the official Porsche warranty:
https://www.6speedonline.com/forums/997/196693-hydraulic-valve-lifters-knocking-after-run-session.html
I've asked my nearest OPC if they can change the oil to 5W50 as per a recommendation in the thread, but they're saying that official Porsche guidance is to use 0W40, thus they won't use anything else. I've told them that the manual states that 0W40, 5W40 or 5W50 can be used for temperatures above -25oC, but they're unmoved.
Given the car is covered by official Porsche warranty, I don't want to threaten that by using non approved oil, so not entirely sure how to proceed. Kind of want to do something as worried the knocking could cause future issues that appear when the warranty ends.
Anyone had any similar challenges or can see/knows something that I'm entirely missing?
Cheers!
PostPosted: Thu Oct 25, 2018 7:23 pm    Post subject: Reply with quote
Can you just clarifie the problem you have .. smoke or tappet noise .. which if only from cold and soon dissapears is pretty normal .
Porsche will use only 0/40 mobil 1 reguardless of the milage .. i know that as i worked there for 10 years .
What Porsche will never know is the actuall oil grade if you use it out side of them .
When an engine lets go for what ever reason we dont test the oil to see if its the wrong grade Smile
If possible a video of the noise will help a lot .. people normally post it on a youtube account but if you dont have one then send it to me and ill post it for everyone .
De.Mort@virginmedia.com
RossJ
PostPosted: Thu Oct 25, 2018 7:52 pm    Post subject: Reply with quote
Hi DeMort,
Good to know Porsche don't go to excessive lengths to get out of potential warranty claims Smile
The noise is a knocking/tapping noise (hard to tell which as it's somewhat subjective) that appears after a run at 3,500 rpm+ and only appears at idle post the run. I only ever press on once the engine is fully warmed up. The noise will go away after a few minutes (max 5) or if I rev it out a bit when in park/neutral. I think the noise eminates from the right hand lower side of the engine as you look at the car from the rear, but the sound seems to travel a bit as I move around the car. No smoke at any time.
I bought the car from RSJ about 18 months ago and during their warranty period they replaced the tappets on one side (left I believe) and did a borescope check as part of the diagnosis that lead to the eventual tappet replacement.
The only thing I have noticed is that sports exhaust tips on the same side as the noise seems to come from both have gas coming from them even when the PSE is turned off. The left hand side only has gas coming from one tip. I'm not sure if the exhaust is a left to right and right to left set up from the engine though, so perhaps a red herring?
I don't have a YouTube account, so appreciate the offer of sending you a video. Will send across.
Cheers, Ross
PostPosted: Fri Oct 26, 2018 4:25 pm    Post subject: Reply with quote
The video you posted was the left side .. link here for everyone ...
https://www.youtube.com/watch?v=JPVMA4d5wrw
Sounds to me like light tappet noise when the engine is hot .. if its louder on the other side then send me another video please and ill post it Smile
Robertb
2002 Porsche 996 Carrera 4S
PostPosted: Mon Oct 29, 2018 2:23 pm    Post subject: Reply with quote
If you have the OPC warranty then tell them the car is making an unusual noise and leave the ball in their court.
jpsh120
PostPosted: Mon Oct 29, 2018 5:34 pm    Post subject: Reply with quote
Re your question about the PSE, the outer pipe only should be working with PSE off.
2007 997 Carrera S - SOLD Sad
