997 : 2004- 76
Boxster : 1997- 16
Cayman : 2005- 18
PostPosted: Thu Oct 25, 2018 5:57 pm    Post subject: Spark plug tube seals Reply with quote
I've had a slight weep on the LH bank for aeons but never to the point it drips. Anyway, last week my mate pointed out a small puddle of oil under the car. Had a gander over the weekend and the rear plug tube was leaking.
Ordered a new one for £6.90 delivered here:
https://www.ebay.co.uk/itm/391996248255
Seemed easier than messing about trying to get the o rings. Arrived today so decided to fit it in my lunch break. 40 minute job lead on the works car park with a 5mm Allen key.
I'll not waffle about fitting as there's already a write-up or two in here. What a did do though was compare the original one with the new one to see how much the seals have changed over time. Measured the larger orange one and there was 2mm difference in the diameters Surprised
No wonder it was leaking!!!!
Easily noticeable in the snaps:
PostPosted: Thu Oct 25, 2018 6:56 pm    Post subject: Reply with quote
This has reminded me ..
Infrasilver posted a pict of a tool he made to remove these a few years back .. i thought it looks usefull so copyed his design.
It works a treat .. far better than the Porsche tool for this job .
I told them at work and got kinda laughed at but what ever .. after a few weeks one guy asked to borrow the tool .. followed by the others over the next few monthes ..
Hats off there as ive not mentioned this before so its due Thumb
PostPosted: Thu Oct 25, 2018 8:23 pm    Post subject: Reply with quote
I used 2 fingers Grin
Just pulled straight out............obviously proving it was goosed!
thecarfixer
PostPosted: Fri Oct 26, 2018 8:12 am    Post subject: Reply with quote
https://www.ebay.co.uk/itm/Porsche-Spark-Plug-Tube-Remover-Puller-986-996-Free-Fast-UK-Delivery/202302102823?hash=item2f1a251d27:g:zt0AAOSw9NdXtsrC:rk:7:pf:0
I used one of these..
edh
PostPosted: Fri Oct 26, 2018 9:38 am    Post subject: Reply with quote
..otherwise known as a boat drain plug (they do work well for the plug tubes though)
Business opportunity here? Smile
https://www.ebay.co.uk/itm/72-TWIST-BRASS-BOAT-DRAIN-PLUGS-BRASS-T-HANDLE-BUNG-FOR-1-25MM-FREE-P-P/132812265001
wasz
1999 Porsche 996 Carrera 2
PostPosted: Fri Oct 26, 2018 9:42 am    Post subject: Reply with quote
Thats a 1" boat drain plug with added Porsche tax.
£4.28 https://www.ebay.co.uk/itm/Brass-Rubber-Boat-Hull-Livewell-Baitwell-Twist-Drain-Plug-Turn-tite-Plug/372159559784
thecarfixer
PostPosted: Fri Oct 26, 2018 11:46 am    Post subject: Reply with quote
Yes - I agree. I just did a quick search and that was the easiest way.
1" Transom plug does the job.
