996 : 1997-2005 43
Boxster : 1997- 12
Macan : 2014- 0
PostPosted: Sun Oct 21, 2018 5:39 pm    Post subject: Fuel Filter ------------- Reply with quote
Hope this aint gonna be a stupid question, but all the cars ive had in the past had fuel filters which i change when it comes to a maintenance service etc.. ok so my question is, is there a fuel filter in the 997? If so where would it be and how often does that need to be changed?
J
Magic919
PostPosted: Sun Oct 21, 2018 6:04 pm    Post subject: Reply with quote
Depending on model of 997, mostly no.
997.2 C2S PDK
997.2 C4S PDK
PostPosted: Sun Oct 21, 2018 6:20 pm    Post subject: Reply with quote
Only the 997 Turbo has a fuel filter .
Magic919
PostPosted: Sun Oct 21, 2018 6:34 pm    Post subject: Reply with quote
I thought some of the GT cars had them too, 997.1 GT3 and RS and the GT2 and GT2 RS.
997.2 C2S PDK
997.2 C4S PDK
PostPosted: Sun Oct 21, 2018 6:35 pm    Post subject: Reply with quote
Sorry .. yes ..
Porsche 997 Turbo 2007 - 2009
Porsche 997 GT2 2008 - 2009
Porsche 997 GT3 2007 - 2009
-- 997 --
PostPosted: Sun Oct 21, 2018 7:09 pm    Post subject: Reply with quote
Thanks for your reply on this, so how does the fueling system work then? There must be some sort of filter mesh in its place? Cos the petrol tank must accumilate crap from petrol to the injectors etc?
J
PostPosted: Sun Oct 21, 2018 7:28 pm    Post subject: Reply with quote
Its a returnless system .. fuel doesnt go back to the tank .. the pump has a mesh filter at its base.
My best guess .. fuel is better these days , less contaminants and so it isnt needed .
But i just fix these so am by far no expert in design Embarassed
EDIT for image and this is USA spec so not our market but its all i could find .
 Filesize:  473.1 KB
 Viewed:  998 Time(s)
-- 997 --
PostPosted: Sun Oct 21, 2018 7:42 pm    Post subject: Reply with quote
Cheers Thumb thats interesting!!!
J
GlenB
PostPosted: Mon Oct 22, 2018 3:42 pm    Post subject: Reply with quote
While we are on odd questions about fuel I thought I might as well post one that's bugging me.
Is / should there be somewhere to hang the fuel cap whilst fuelling? Mine has a long rubber "string" and i don't really fancy leaving it dangling down the side of the car. I have to kind of balance it on the top of the nozzle but this isn't great either.
There is a hole on the fuel flap that looks like something should poke in, but I have no poker Very Happy
infrasilver
Fast & Furious
Fast & Furious
2001 Porsche 996 Targa
PostPosted: Mon Oct 22, 2018 4:36 pm    Post subject: Reply with quote
The filter is just a screen (as mentioned) that is fixed and in the tank, when I removed my pump the other week the mesh screen filter did have some particles on it which I cleaned up before refitting. The 996 one is at the very bottom of the tank so I do expect a little bit of crud after 17 years of filling up.
PostPosted: Mon Oct 22, 2018 6:26 pm    Post subject: Reply with quote
@ GlenB
Couple of images , with the top one showing a small hook on the far right of the image .. if you have this then it should hold the cap but i have a feeling this is USA spec only.
I have to admit though .. this is something ive never taken any notice of Embarassed
Reguards the pump .. if you have small bits of black plastic then the pump may well be on its way out .. at least the ones ive seen that have died have all had black plastic in the tank .
Pump failure is pretty rare though .. seen it a hand full of times in all the years ive worked on these (14 ) .
 Filesize:  135.8 KB
 Viewed:  862 Time(s)
 Filesize:  114.74 KB
 Viewed:  862 Time(s)
infrasilver
Fast & Furious
Fast & Furious
PostPosted: Mon Oct 22, 2018 6:45 pm    Post subject: Reply with quote
I used to have Audi's that had the caps that had a groove in them and lodged on the filler flap when filling up, as there is no writing on the one in the second picture, it could be an Audi one?
PostPosted: Mon Oct 22, 2018 7:03 pm    Post subject: Reply with quote
Second picture i just lifted from here ..
https://picclick.co.uk/Porsche-Boxster-Fuel-Cap-Porsche-996-997-273330515809.html#&gid=1&pid=4
First picture from here ..
https://www.suncoastparts.com/product/99720106300AND99750471100.html
Ill have a look at a 997 tomorrow .. as said ive never taken any notice of this before but now im intrigued Smile
infrasilver
Fast & Furious
Fast & Furious
PostPosted: Mon Oct 22, 2018 7:08 pm    Post subject: Reply with quote
Same, I just flip mine over the filler flap which is not ideal.
EDIT: Googling 997 caps and they seem to have the slot to mount on the filler flap, I think I will order one for my 996.
vlad
PostPosted: Mon Oct 22, 2018 7:24 pm    Post subject: Reply with quote
I am sure there is a book on the inside of the fuel filler flap door, hang by the cord from there
PostPosted: Tue Oct 23, 2018 7:29 am    Post subject: Reply with quote
 Filesize:  1.33 MB
 Viewed:  758 Time(s)
infrasilver
Fast & Furious
Fast & Furious
PostPosted: Tue Oct 23, 2018 5:39 pm    Post subject: Reply with quote
Cheers DM, I found that little metal tang on the flap today and will be using that from now on, can't believe I'd not realised that is what it was for, saves scratching the paint with the 997 cap or just dangling it. Thumb
GlenB
PostPosted: Wed Oct 24, 2018 3:04 pm    Post subject: Reply with quote
Thanks all, can't believe I hadn't noticed that little tag, or that others hadn't either. We'll that's going to make things a tad easier!
