964 : 1989-1993 5
Boxster : 1997- 19
Cayenne : 2003- 3
Macan : 2014- 1
v6matt
PostPosted: Tue Oct 16, 2018 4:38 pm    Post subject: A few niggles - Thoughts? Reply with quote
So, 1 week into ownership and my OCD is in full swing Laughing
Thoughts on the below ?
1) Squeaky rear spoiler when manually raising. I was just going to buy some 'dry' PTFE 3-in-1 spray and spray the areas that move. Thinking the dry type to avoid it collecting lots of dirt like you normally do with traditional sprays.
2) The wing mirror glass doesn't move smoothly, it is almost a juddery movement so it looks like this needs some attention. How do I get at the mechanism/what do I spray?
3) There is a really irritating rattle from what appears to be the top left speaker on the dash, initially I thought it was static but it makes the noise even with the radio off. Is this a known issue? What is the cure?
Other than these bits, absolutely loving this car. What a blast !
2008 Carrera 4 - Gen 1 997
FZP
Paul Ricard
PostPosted: Tue Oct 16, 2018 4:55 pm    Post subject: Reply with quote
The rear spoiler can be sorted with some graphite lubricant. I had the same issue on my gen 2 and OPC sorted it for me.
Mirror I can't help with
The find the rattle game is amazing fun. It moves around on you as you narrow down the source. I thought the speaker rattled also, only to find it was the homelink blanking button in the overhead light cluster Dont know
Good luck with items 2 and 3
v6matt
PostPosted: Tue Oct 16, 2018 4:57 pm    Post subject: Reply with quote
Hmm thanks, in terms of the rattle I went straight to the homelink after seeing those lose flimsy covers but alas not. Doesnt seem to be anything I can compress to stop the vibration....yet
Magic919
PostPosted: Tue Oct 16, 2018 5:19 pm    Post subject: Reply with quote
My mirror needed a new motor to sort it. You could pull off the glass and try to sort it.
997.2 C2S PDK
997.2 C4S PDK
PostPosted: Tue Oct 16, 2018 7:20 pm    Post subject: Reply with quote
Ill just post what i think so not doubting what anyone else might say ..
1 / The ram each side is dirty , clean it .. lub might help but Porsche instructions are to clean it .
2 / You cant lub anything .. its x2 small motors on a plastic arm with teeth on it , replacement i would have thought but once the mirror is set you dont tend to move them again.
3 / There are several places that can cause noises .. speakers and not just the cover , instrument cluster and surround , panels each side of the speakers .. bit of a garage job really .
Magic919
PostPosted: Tue Oct 16, 2018 7:30 pm    Post subject: Reply with quote
With the memory function, the mirror drops whenever I select reverse. That made the judder more annoying. Eventually the motor wouldn’t tip down.
997.2 C2S PDK
997.2 C4S PDK
Richtw
PostPosted: Tue Oct 16, 2018 7:42 pm    Post subject: Reply with quote
My dash speaker buzz was due to the foam compressing under the grill, the grill can be popped off from the middle of the dash and then the trailing edge Just remove it and see if it clears - mine did so just felted the grill. Easy enough if that is what is causing it. If not then could be the air vent!!
2010 997.2 C4S
DucatiRob
PostPosted: Tue Oct 16, 2018 7:43 pm    Post subject: Reply with quote
I had the same bundle of fun and hours of entertainment playing hide and seek with rattles! To be fair, it was after ripping out most of the interior to replace all the speakers, the source of the rattle is quite often nowhere near where you think it's coming from frustrated I did have a rattle from one of the dash tweeters, this was because the Focal units I replaced the Bose ones with wasn't quite seated properly! Best way I found to locate rattles was to have a mate in the car with a narrow cone of cardboard to listen for the source and prodding buttons, panels and anything that might rattle or buzz!!
Mercedes CLK DD
Ducati 996
PostPosted: Tue Oct 16, 2018 8:36 pm    Post subject: Reply with quote
when you spot another 911 driver and you see the expression on their face its natural to assume ah they are driving a 911 they are consertrating and foccused but no the truth is they are listening hard for the location of yet another bloody rattle. I removed virtually the whole of my interior twice on the hunt for a rattle I even had my tech use his borescope in gaps and between the inner and outer metal panels (we did remove 3 rivet heads from the rear arch space between panels )but that wasnt the cause , finally found a loose cable running along the inside of the panel where the high level brake lights fitted. that was one , then a tip gear lever spring was another , a seat belt housing loose was another Grin Thumb
systech1
PostPosted: Wed Oct 17, 2018 2:35 am    Post subject: Re: A few niggles - Thoughts? Reply with quote
I used this DIY maintenance procedure from Rennlist to cure the noise on my spoiler..
https://rennlist.com/how-tos/a/porsche-997-how-to-service-rear-spoiler-384158
..a bit fiddly but worked a treat. You could just try and clean the struts once the spoiler is lifted first to see if that helps..and then lubricate them slightly if that doesn't work even though Porsche says not to!
Long time Porsche fan. Previous cars include 911T 2.2, 911E 2.2, Carrera 3.0, 986 Boxster S. Current car is 997.2S Manual (with PSE, H&S Backbox bypass, Sports Chrono, SSK, Carrera Sports wheels, Sport Design steering wheel etc.)
v6matt
PostPosted: Sat Oct 27, 2018 6:28 pm    Post subject: Reply with quote
Ok, so an update on this
1) Wing Mirror - This has fixed itself, mine auto dips when reversing and so it was rather frustrating. It must have not been reversed in a while, and my daily London parking has brought it back to smooth bliss
2) Rear spoiler still squeaks but following the guide, I am going to buy some dry PTFE spray and put into the little hole. That will reduce the chance of it picking up grit but also do the job
3) The rattle is still being investigated!
PostPosted: Sat Oct 27, 2018 6:51 pm    Post subject: Reply with quote
Pm me an email addy .. ive got something to send you for the spoiler noise .
