996 : 1997-2005 43
Boxster : 1997- 13
Cayman : 2005- 12
Macan : 2014- 0
mikee
PostPosted: Mon Oct 15, 2018 3:52 pm    Post subject: Wiper Blades Reply with quote
Hi all
So, when I bought the car i removed the old style Bosch wiper blades that were fitted as they were a bit old and replaced with some new style Bosch Aero Blades that were apparently the correct part for the car, except....
They're awful. They miss parts of the screen and unless its really wet or you give it full beans with the washers they don't glide smoothly over the windscreen. Being a 2010 car I thought the newer style aero blades would have been standard but I'm guessing not.
Is this a common problem or just a dodgy set of blades? Is it advisable to go back to the old style ones?
997 Gen2 C2S PDK
Magic919
PostPosted: Mon Oct 15, 2018 4:19 pm    Post subject: Reply with quote
I stick with the normal Bosch ones. The 997 never left Zuffenhausen with aero blades on the front.
997.2 C2S PDK
997.2 C4S PDK
FZP
PostPosted: Mon Oct 15, 2018 5:43 pm    Post subject: Reply with quote
I'd start with the basics. Clean the screen with a white spirit to remove any residue. Things like old RainX and the like can make the wipers under perform and chatter.
I believe there is alot of love for the PIAA blades here.
ninenineseven
PostPosted: Mon Oct 15, 2018 5:46 pm    Post subject: Reply with quote
Standard wiper blades from Porsche are not the Bosch aero ones and work perfectly. Thumb
s70rjw
PostPosted: Mon Oct 15, 2018 6:11 pm    Post subject: Reply with quote
I've got the Bosch aeroblades and they work fine. The last cm of the nearside screen curvature doesn't get wiped as the aeroblades does not curve around the screen. I only notice this when cleaning the screen while washing the car. On a rhd car, I can't see any downside.
As has been mentioned PIAA get rave reviews, you may want to try them.
Bar Keepers Friend is a fantastic product for taking every last bit of bug splatter /sap/ screen coating etc off the screen, leaving your wipers largely redundant above 40mph.
Good luck. Thumb
997.2 manual
James M-S
2009 Porsche 997 Carrera 2
PostPosted: Mon Oct 15, 2018 6:23 pm    Post subject: Reply with quote
Bar Keepers Friend seconded. It’s a slightly abrasive cream, for a couple of quid. You can get it in powder form if you want a slightly stronger paste rather than cream.
It has the same effect as Autoglym Screen Polish, but a fraction of the cost.
You’ll find it in B&Q or some supermarkets.
TonyC911
PostPosted: Mon Oct 15, 2018 7:06 pm    Post subject: Reply with quote
Agree
They might look a bit crap but they do work well!
OPC changed mine as my warranty dictates only oem parts... Rolling Eyes
2007 Carrerra S
2005 Boxster S
2003 Boxster 2.7
1998 Boxster 2.5
NLW73
PostPosted: Mon Oct 15, 2018 7:14 pm    Post subject: Reply with quote
what size on the 997? online saying 22 inch for both blades.
997 C2s Schwarz
Jam911
PostPosted: Mon Oct 15, 2018 8:02 pm    Post subject: Reply with quote
Used PIAA blades for 8 years, silent and perfect.
Current '07 997 C4S
Ex '99 2.5 Boxster
99pFlake
PostPosted: Tue Oct 16, 2018 8:05 am    Post subject: Reply with quote
I swapped over to the aftermarket Aerotwin blades simply because I think the factory pantograph ones look dated. I've had no issues other than the blades missing the last little edge of the nearside windscreen (which doesn't bother me at all).
With regard to Barkeeper's Friend, make sure you rinse the windscreen and car thoroughly after using it - it's basically feldspar and oxalic acid which can damage your paintwork if it sits on it.
mikee
PostPosted: Tue Oct 16, 2018 3:27 pm    Post subject: Reply with quote
Great, thanks for the tips. I think I'll go back to the old school Bosch ones if that's what OPC fit.
Maybe its just a duff wiper that I've got with these Bosch Aerotwin ones, but they're so noisy and juddery it's just not very Porsche-like Sad
997 Gen2 C2S PDK
Martian
2007 Porsche 997 Turbo
PostPosted: Tue Oct 16, 2018 4:13 pm    Post subject: Reply with quote
FZP wrote:
........Clean the screen with a white spirit.....
Hopefully you meant Methylated Spirit! Surprised
FZP
PostPosted: Tue Oct 16, 2018 4:46 pm    Post subject: Reply with quote
Lost in translation from AU to English Thumb
