997 : 2004- 76
Boxster : 1997- 16
Cayman : 2005- 18
Shurv
PostPosted: Mon Oct 15, 2018 7:43 am    Post subject: High Speed vibration Reply with quote
I get a pretty big vibration at speeds over 130mph, in Germany of course, that feels is coming from the rear of the car. I'm sure it isn't wheel balance, and the suspension has had the all clear from centre gravity. Might it be a sign that the engine mounts are on their way out? There is no sag from them but they are the original 2002 79k miles ones. Any ideas?.
996 C4S Arctic Silver Black leather
Martin996RSR
PostPosted: Mon Oct 15, 2018 8:06 am    Post subject: Reply with quote
I had a similar thing and it turned out to be wheel imbalance but it was at 90mph. What makes you think it's not wheel imbalance?
cvega
PostPosted: Mon Oct 15, 2018 8:49 am    Post subject: Reply with quote
it could be a wheel slightly buckled, hit any potholes recently? get them balanced again just to be sure. Balancing doesn't last forever... especially on our roads as is. Cheap fix possibly too.
2003 996 C2
2017 Leaf 30kWh
gone: 2010 335d, 2007 Cayman S, 2008 Civic Type-R, 1992 MR2 Turbo ,1994 MR2 N/A
Grey996
PostPosted: Mon Oct 15, 2018 10:47 am    Post subject: Reply with quote
Tyre pressures?
2002 Porsche 996 C2
Shurv
PostPosted: Mon Oct 15, 2018 12:56 pm    Post subject: Reply with quote
I will fit my winter wheels next week when I have a week off, and then see if it still vibrates. If it doesn't I'll get the rims checked out. The rear tyres are pretty much gone, so I will replace the whole set over the winter in case I have a tyre causing the problem (the fronts are approaching 3mm anyway). It does point to wheels or tyres doesn't it?
Jamesx19
PostPosted: Tue Oct 16, 2018 6:03 am    Post subject: Reply with quote
Wheel vibration would appear at 70 ish mph initially I'd have thought.
I did have some Powerflex gearbox mounts in recently, and over 100 leptons there was vibration. I took them out and it disappeared. On that basis maybe gearbox rubber mount needs looking at? The engine and gearbox assembly are only mounted in 3 locations, and the gearbox mount does the end with the driveshafts etc.....
Good luck
1998 C2 Manual + The Full Hartech.
Martin996RSR
PostPosted: Tue Oct 16, 2018 10:20 am    Post subject: Reply with quote
Wheel vibration can appear at any speed. Different levels of imbalance become apparent at different speeds.
Magic919
PostPosted: Tue Oct 16, 2018 1:41 pm    Post subject: Reply with quote
My 996 felt ok in UK but vibration was at 140 up on autobahn. That was wheel balance.
997.2 C2S PDK
997.2 C4S PDK
wasz
1999 Porsche 996 Carrera 2
PostPosted: Tue Oct 16, 2018 3:24 pm    Post subject: Reply with quote
I wouldn't worry about it. I mean, how often do you go 130mph?
Jamesx19
PostPosted: Tue Oct 16, 2018 7:07 pm    Post subject: Reply with quote
Ah ok. Makes sense. I don't go fast enough I reckon!
PostPosted: Tue Oct 16, 2018 7:23 pm    Post subject: Reply with quote
Ill just add .. rear wheel imbalence .. common cause of vibrations and always the first place to start .. ask for fine balence if your local garage does it .
