997 : 2004- 76
Boxster : 1997- 16
Cayman : 2005- 18
peterzoom
2001 Porsche 996 Carrera 4
PostPosted: Sat Oct 13, 2018 10:04 am    Post subject: 3 spoke steering wheel airbag Porsche crest Reply with quote
Please don't mock too badly here, but the crest in the centre of my steering wheel has been scored heavily when my wife was driving. Some sort of diamond ring steering wheel interaction. Don't ask, please, as even after hearing the story of how it happened first hand (no pun intended) Very Happy I am still none the wiser.
Every time I look at it it is bugging the life out of me. I have asked at my OPC if the badge is available as a part and apparently it isn't, just a a full replacement air bag, mucho dinero!
I guess i could pick up a replacement wheel centre on ebay but I thought I would ask her first to see if anyone knew if the crest in the wheel centre is the same as any other that might be available as a stand alone part???? worship
RobIpswichUK
1994 Porsche 993 Carrera 2
PostPosted: Sat Oct 13, 2018 10:16 am    Post subject: Reply with quote
See if you can get a blown airbag from a scrappie, and see how easy it is to remove the badge. If easy and in good condition do that and swap but make sure battery has been disconnected for a while otherwise risk you bag going off
Rob
'94 C2 Iris Blue (+ White Stripes!) Cup 2's, Big Ovals, FSD's/Eibach, OMP Strut Brace, 200 Cell Powerspeed Cats, 1.75" Hollamby Exhaust bypass, Carnewal FPB.
Mercedes SL (R230 lowered + AMG wheels)
Range Rover Sport V8 (L320 chipped)
TT Roadster (standard - wife’s daily!)
W211 E320CDI Barge (must not forget - NEED TO SELL!)
E91 320d SE Touring (must not forget - NEED TO SELL!)
RobIpswichUK
PostPosted: Sat Oct 13, 2018 10:17 am    Post subject: Reply with quote
See if you can get a blown airbag from a scrappie, and see how easy it is to remove the badge. If easy and in good condition do that but make sure battery has been disconnected for a while otherwise risk you bag going off
Rob
mark pearce
Approved Trader
PostPosted: Sat Oct 13, 2018 12:47 pm    Post subject: Reply with quote
The reason why the badge is unavailable separately is if you stick on a badge yourself and the airbag goes off the badge will be propelled towards you like a bullet.
Hence its only available as part of the airbag
Its not Porsche trying to rip you off, they're trying to stop you injuring yourself
Stirlings The Low Mileage Porsche Specialists
mark@stirlings.co.uk
Tel 01736 757755
www.stirlings.co.uk
Passion for Perfection
Why risk the alternative?
PostPosted: Sat Oct 13, 2018 2:09 pm    Post subject: Reply with quote
It can be done , it is a pain and as its held in by a stud fixed on the back of the crest that goes into a hole in the airbag you will almostt certainly have to cut it off in which case the only way to allow the new one is to stick it in place , the downside of this is in a accident it may ping off and hit you in the face whereas its designed to stay attached to one half the airbag by the stud. So my suggestion is do it knowing what your doing or buy a used airbag with crest.
heres a pic of my custom painted crest , which is how I know the above.
 Filesize:  88.83 KB
 Viewed:  850 Time(s)
C4-STORM
2004 Porsche 996 Carrera 4S
PostPosted: Sat Oct 13, 2018 6:51 pm    Post subject: Reply with quote
There's one here which also has a black/silver crest as opposed to a gold one.
I have been watching as I fancied it for mine as a change and to tie in with my enamelled bonnet badge but then it wouldn't match the crest on the gear selector.. Rolling Eyes
May be an option for you:
https://www.ebay.co.uk/itm/GENUINE-PORSCHE-986-996-BLACK-3-SPOKE-STEERING-WHEEL-AIRBAG-99680308902-/392131458771
2004 C4S Coupe 3.6 Tiptronic S ~ Basalt Black ~ Black Crested Sports Seats ~ Alcantara ~ S/R Delete ~ WEVO Engine Mounts ~ K&N Induction Filter ~ DesignTek Sports Exhausts ~ Quad Tips ~ RUF Hubcentrics ~ RUF Sports Springs ~ Paddle Shift Steering Upgrade ~ Rear Wiper Delete ~ Smoked Rear Indicators ~ Smoked 3rd Brake Light ~ Silver Dash Bar Hack™
demon
PostPosted: Mon Oct 15, 2018 8:17 am    Post subject: Reply with quote
It can be done.... carefully!
There is a press circlip holding the end of the stud on the other side of the face of the airbag.... cut/destroy the circlip to retain the stud on your replacement, then fit with a new appropriate circlip thingy to ensure that your "new" badge is held in place as the factory intended
I replaced a coloured crest with a 2000 version, as my originally was missing a couple of the enamel(?) pieces and too bling for my taste anyway
1998 Carrera - Black, no sunroof, manual, cable throttle, IPD plenum, 200 cell x pipe, cargraphic backboxes, Ohlins R&T, LSD, polybushed, Girodisc brakes, custom ("shaved") GT3 RS decklid, 997 sports seats, litronic headlights, RUF wing mirrors, Hartech rebuild, >240,000 miles
peterzoom
PostPosted: Mon Oct 15, 2018 12:13 pm    Post subject: Reply with quote
Thanks for all the replies, I am building up a picture of what can be done, safely. With regard to the quote above, do you recall where you sourced the new crest?
it is astonishing just how much I am finding my eyes drawn to the damage, even if it is slight Confused
demon
PostPosted: Mon Oct 15, 2018 12:29 pm    Post subject: Reply with quote
Mine came from ebay - essentially a guy selling several where the flap had been cut from a (deployed?) airbag centre
The general advice is to remove everything from the car and allow plenty of time for any "residual charge" to dissipate... don't scuff your feet along the floor and build up a static charge when handling, etc... I don't think there is any great issue in handling airbags that have been disconnected from a car, but the airbag part is typically referred to as the "bomb" on US forums, which is sufficiently alarming to at least make sure you employ the sensible precautions when handling!
