996 : 1997-2005 43
Boxster : 1997- 13
Cayman : 2005- 12
Macan : 2014- 0
Creationblue
PostPosted: Mon Oct 08, 2018 6:01 pm    Post subject: Tip fault code Reply with quote
Hi all
Took my car for a service today and an inspection, all good news as far as the engine and suspension is concerned but it flashed up with a fault code P0740. I got him to change the trans fluid as a matter of course, thing is I didn’t seem to have an issue with the tip, he’s saying the TC is as fault and I’m not doubting him but as I don’t have any symptoms I’m not likely to get the new box fitted just yet at a cost of £2.5k. What’s everyone’s thoughts?
'99 C2.1 Tip Vert
‘08 X3 3.0SD
'70 VW Westy Corvair T2
PostPosted: Mon Oct 08, 2018 6:35 pm    Post subject: Reply with quote
The fault code referes mainly to the Torque convertor lock up clutch .
At a set Rpm you want a one to one ratio between flywheel and the gearbox .. upto this point it .. well .. it kinda slips like a manual clutch when your pulling away ..
Details in the picture .
Oil and filter is a good start along with the fact you havent had any problems .. also you can sometimes get this fault without actually having a problem .. a spurious code we tend to call them .
For now i would suggest just drive and monitor it .. if there is a problem you will get repeated fault codes and the car will start to show symptoms .
 Filesize:  59.24 KB
 Viewed:  600 Time(s)
Creationblue
PostPosted: Mon Oct 08, 2018 8:56 pm    Post subject: Reply with quote
I guess if I drove another I might notice the difference but for now I shall monitor it and leave it till next year.
'99 C2.1 Tip Vert
‘08 X3 3.0SD
JKH112
2001 Porsche 996 Carrera 2
PostPosted: Sat Oct 13, 2018 1:55 pm    Post subject: Reply with quote
Out of interest where did you have it serviced?
