997 : 2004- 84
996 : 1997-2005 46
Boxster : 1997- 14
Cayman : 2005- 17
Cayenne : 2003- 7
Macan : 2014- 0
knw911
PostPosted: Tue Sep 25, 2018 10:54 am    Post subject: 996 wheel replacement Reply with quote
Hi guys and gals
I'm looking to swap out my standard wheel with a Momo Mod 07.
There is a lot of info out there, but its all a bit bitty and cant find anything complete, end to end.
systemmeister had a great post, but has some pics missing.
From what I can see, I need to buy the following parts:
1) Momo hub - MOM7004
2) airbag bypass - https://www.ebay.co.uk/itm/ALL-OHMS-SRS-AIRBAG-RESISTOR-RESISTORS-0-25W-2-AMP-FUSED-BYPASS-FAULT-LIGHT/261530083984?_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20160908105057%26meid%3Da8faf60966ca4ad5929a4781bc3b0324%26pid%3D100675%26rk%3D6%26rkt%3D15%26mehot%3Dpp%26sd%3D312246196907%26itm%3D261530083984&_trksid=p2481888.c100675.m4236&_trkparms=pageci%3A2e96a8fc-c0b1-11e8-bdff-74dbd1803b58%7Cparentrq%3A105c714b1660a9cad9a96c85fff99901%7Ciid%3A1
3) Horn button
Is there anything else? any other hints or tips. Anyone want to helpl me do it with ahahah?
PostPosted: Tue Sep 25, 2018 1:41 pm    Post subject: Reply with quote
Page 13 if it doesn't take you there:
http://911uk.com/viewtopic.php?t=118164&postdays=0&postorder=asc&start=240
knw911
PostPosted: Tue Sep 25, 2018 2:24 pm    Post subject: Reply with quote
thanks, thats helped a bit, but possibly also confused me further as it seems a bit different to http://911uk.com/viewtopic.php?t=96290&sid=ea4f4d3beecba152b28daa6a59fc5fb6
Maybe thats the missing pics..
hmmmmmm.
Marky911
PostPosted: Tue Sep 25, 2018 4:41 pm    Post subject: Reply with quote
Cheers H mate. Thumb
KNW, yes there's lots of information out there with bits and bobs missing.
As long as you buy the parts I did it all becomes apparent. Wink
I should have done a better step by step guide but like I say you'll get there by combining the various threads.
Buy the copper pad to power the hub, the end connector (for the wire you need to extend and take into the currently empty hole in the main wiring unit) and also a 2.8 ohm resistor to keep the airbag light off.
First two from Porsche, resistor from eBay.
I was dreading it a bit after the problems Dammit had with his horn but the actual physical fitting etc is very simple.
Ping me a message if you get stuck. Thumb
knw911
PostPosted: Wed Sep 26, 2018 10:47 am    Post subject: Reply with quote
thanks fella.
I will get the bits from Porsche and give it a go.
Did you use washers to "pad out" the stem that I've seen people do?
Stotty
PostPosted: Wed Sep 26, 2018 12:05 pm    Post subject: Reply with quote
It's hit and miss if the horn works... just depends on your particualr car.
My Indy have had the car for the last 2 days for springs shocks and to wire the horn/airbag resistor on the Momo Cup wheel I bought.
They have not been able to get the horn working due to the steering column not earthing. Said they've seen nothing like it before - Works with the ignition off, but not when it's on.
2000 996, C2, manual, arctic/metropole, sunroof delete, Koni shocks, H&R -30 spring, Cup wheel, 170k miles. 2018 Touareg RLine Plus
knw911
PostPosted: Wed Sep 26, 2018 12:07 pm    Post subject: Reply with quote
Thats a little worrying.. cant you run a cable from the negative to an earthing point somewhere?
knw911
PostPosted: Wed Sep 26, 2018 12:08 pm    Post subject: Reply with quote
Chap - where did you get your PORSCHE decals made? would love to add one to mine.
knw911
PostPosted: Wed Sep 26, 2018 12:09 pm    Post subject: Reply with quote
Wheel has arrived...
Sundayjumper
1999 Porsche 996 Carrera 2
PostPosted: Wed Sep 26, 2018 12:12 pm    Post subject: Reply with quote
Is this the same bunch of clowns that Dammit used ?? Laughing
It works with the ignition off because the steering lock makes a connection between the parts of the steering column. Mine was exactly the same, you just need to add an earth, it was easy.
Alternatively, pay them ££££££s to fit a different column.......
Sundayjumper
PostPosted: Wed Sep 26, 2018 12:15 pm    Post subject: Reply with quote
Stotty / knw911 - whereabouts in the country are you ? If you're near Sandhurst, Berks I'll give you a hand.
Stotty
PostPosted: Wed Sep 26, 2018 12:25 pm    Post subject: Reply with quote
I think Dammit uses Precision. Mine was at GT One.
I'm in Weybridge, so only 30 mins away from you... if you can help I'd be very happy!
knw911
PostPosted: Wed Sep 26, 2018 12:28 pm    Post subject: Reply with quote
You're about 1.5 hours away, but totally worth the trip for me to pop over on a weekend to get some help, but also, good to meet a fellow 911'er.
Sundayjumper
PostPosted: Wed Sep 26, 2018 1:03 pm    Post subject: Reply with quote
I'm free on Sat 6th if you want to pop over.
knw911 - that's a long drive ! You're welcome to come over but I'd feel bad if we couldn't get it working and you had a wasted journey. Weybridge is not so bad.
knw911
PostPosted: Wed Sep 26, 2018 1:16 pm    Post subject: Reply with quote
I'm used to much longer journeys than that, and am often heading over that way.
I don't want to inconvenience you though. How long do you think the job would take?
Sundayjumper
PostPosted: Wed Sep 26, 2018 1:33 pm    Post subject: Reply with quote
If all goes well an hour or so should cover it. But life is never that simple eh ? Allow a couple of hours. I have plenty of coffee.
Stotty
PostPosted: Wed Sep 26, 2018 1:57 pm    Post subject: Reply with quote
That's super generous... If you're sure I'd be happy to come over.
Paynewright
PostPosted: Wed Sep 26, 2018 2:57 pm    Post subject: Reply with quote
I wish you lot wouldnt keep talking about nice upgrades its getting too expensive!!
knw911
PostPosted: Wed Sep 26, 2018 3:58 pm    Post subject: Reply with quote
Check ebay - i got my wheel for £70 delivered.
Wheel - £70
Hub - £65
Horn brass connector - £15
pin 71 pin - £1
misc stuff £5
£156 ish - not too shabby that
Marky911
PostPosted: Wed Sep 26, 2018 4:13 pm    Post subject: Reply with quote
Hi KNW,
I popped along to my local graphics place, A to Z stickers on Westgate Road, Newcastle. Any decent graphics place should have the various Porsche fonts though.
3mm high by 35mm long.
Get a couple as they're a bit fiddly to get spot on. Wink
Good luck at the weekend chaps. That's a nice offer by SJ. Thumb
