997 : 2004- 71
Boxster : 1997- 13
Allan E
PostPosted: Mon Sep 24, 2018 6:32 pm    Post subject: Windscreen washers Reply with quote
The near side screen washer appears to have stopped working, fearful of trying too hard to remove it from the bonnet, so can someone advise me the correct way to free it.
I have checked that the jets are clear so the blockage may be in the water tubing.
Anything else that I need to look for?
1995 Carrera in Guards Red
1987 Mercedes 300SL (R107)
ollster
PostPosted: Mon Sep 24, 2018 6:33 pm    Post subject: Reply with quote
Try an open safety pin in each spray jet, normally works for me
jkeith
PostPosted: Mon Sep 24, 2018 6:42 pm    Post subject: Reply with quote
Hi Allan,
I had problems with both of my windscreen washers. It turned out to be as a result of lack of use and a build up of dried polish over the nozzles.
As you only have a problem with one nozzle, the blocked one will not be purged by using the pump. I wonder how you might have tried to clear the nozzle? I used the narrowest needle in my 'darning kit'. I also put hot water into the reservoir after I had drained it of the cold water and de-icer. Cleared the problem but not sure which of the two did the trick.
I'm sure the hot water helped to dissolve any waxing or polish in the nozzle.
Hope this helps. I hear your car looked stunning at Whitley Bay!
Cheers, Keith.
2005 996 GT3
1986 Grand Prix White 3.2 lhd whaletail
2005 BMW 325 M sport
1986 944 turbo (sold)
968 Clubsport (sold)
964 (sold)
Allan E
PostPosted: Mon Sep 24, 2018 6:52 pm    Post subject: Screen washers Reply with quote
Hi Keith, I should have added that the headlight jets are working fine, with plenty pressure as is the offside screen jets. I used a very fine needle to clear any crap, the needle had no resistance suggesting it was clear.
I may try blocking all jets except the non working one and hope it clears when operating the washer.
Very enjoyable day at Whitley Bay after an early shower, only two Porsche’s there, mine and a 997 cabriolet in yellow.
ColinC
PostPosted: Mon Sep 24, 2018 8:04 pm    Post subject: Reply with quote
If you push the nozzle from the rear under the hood (ooo err missus) by applying firm pressure you can tilt the washer up at the rear as this is where the retaining clip is........do not use a screwdriver.
Soak it in warm water and gently blow it to clear ........I am still talking about the nozzle.
Allan E
PostPosted: Mon Sep 24, 2018 9:07 pm    Post subject: Screen washers Reply with quote
Many thanks Colin, attempt that asap.
993tt
PostPosted: Tue Sep 25, 2018 8:31 am    Post subject: Reply with quote
In the past I have found 'waggling the pipe work' under the hood, just before it joins the jets can restore full operation. It appears to sometimes get enough of a kink in it to reduce or stop flow.
PostPosted: Tue Sep 25, 2018 8:44 am    Post subject: Reply with quote
In future it may be best to ask the MOT tester to 'test' operation of screen washer several times instead of the once a year function Thumb
Allan E
PostPosted: Mon Oct 08, 2018 4:18 pm    Post subject: Windscreen washers Reply with quote
Found the problem, slid the washer jet out and approx. three inches back the pipe was creased at 90 degrees. Due to its age the pipe was very hard so after clamping it over the crease with a ratchet clamp and leaving it overnight it has straightened it enough to work.
