Does your 996 "rock" on the handbrake a little?
wasz
Paul Ricard
28 Dec 2012
3,107
When you stick the handbrake on my car on a hill, it rocks slightly forwards. It is secure and has passed MOTs like this.
Its always done this, I never thought anything of it as I've had other cars do it.
I took it for laser alignment check after fitting new tyres, just at a normal tyre place, and they drove it onto some "cups" that the wheels sit on. The cups let the wheels move around a bit whilst they adjust the geo.
The car wouldn't sit still on the cups - this slight "rocking" meant it would drop off the cups.
Last place I had it aligned had the hunter system, I think that used flat plates rather than cups.
Does yours rock slightly on the handbrake? Mine did have new shoes this year.
It's you brake shoes moving backwards and forwards. The have some play in the position they sit in. You apply the handbrake, they lock to the inside of the disc bell and then they move from their natural seated position until they lock up against other internal parts.
When a geometry check/adjust is done you should use a brake depressor .. basically it presses the brake pedal and stops any movement.
Handbrake as Alex has said will allow a small amount of rock .
Ok thanks I thought it was normal.
It ain't going anywhere with the handbrake on, it just rocks a little when applied and then foot off the brake.
The tyre place was making out like my car was dangerous, said it would fail an MOT. Except its always done it and never had an advisory. They did offer to "book it n and sort it" which is when my "being taken for a mug" senses started tingling. Strange they didn't just do the check and charge me for it too in that case.
I don't even think it even needs another alignment but it doesn't hurt to check when fitting tyres. I will go somewhere that knows what they are doing then, so hard to find somewhere local thats actually competent and has decent kit!
124,605
1,442,016
49,038
DD77
