PCCB Ceramic Brake on a C2
blanc
23 Mar 2018
81
Hi All
Will the PCCB Ceramic Brake and caliper kit from a c4s fit q 2003 C2?
Not directly, the caliper bolt spacing is different. You will need GT3 uprights ideally.
Its the big lump of metal that your brake caliper, tie rod, lower control arm, hub, damper etc etc bolts to.
Steering knuckle, hub carrier, upright, all the same things but under a different name.
GT3 fronts have improved geometry and different caliper mounting points than the C2. - Hard to find used and expensive new.
Have you tried Pagid RS 29 Yellow pads to replace in your standard callipers along with ATE Super blue racing brake fluid change? You may be astounded at the difference for a snip of the price of PCCBs...
124,550
1,441,443
48,964
toe-nee-g
