996 : 1997-2005 43
Boxster : 1997- 13
Cayman : 2005- 12
Macan : 2014- 0
jonno_
2005 Porsche 997 Carrera 2S
PostPosted: Wed Oct 17, 2018 4:16 pm    Post subject: Reply with quote
Good to get sorted.
Did you got for be the low temp thermostat?
Simmokj
PostPosted: Sun Oct 21, 2018 10:45 pm    Post subject: Reply with quote
Huh?
This was the temp sensor issue. Thumb
PostPosted: Mon Oct 22, 2018 6:57 pm    Post subject: Reply with quote
For some reason i missed this post .. Embarassed
Just on the off chance this comes back .. which i doubt as you have found a fault but ..
On Tiptronics there is a heat exchanger .. if the electric valve fails then this is permanently open .. what happens is the car sees the oil temp being higher than the coolant temp due to pretty much a radiator cooling it , it thinks there is a fault with the temp sensor so you loose the temp gauge and the red light comes on .
This often resets when cold .
valve is the other side of box in your picture.
Goto page Previous  1, 2
Page 2 of 2
