Yas Marina
- Joined
- 20 Dec 2009
- Messages
- 8,949
HSC911 said:Try driving it :judge:
:grin:
spongebob squarepants said:HSC911 said:Try driving it :judge:
:grin:
I could but it won't start :grin:
deMort said:If you look at the trim panel the wipers go in then n/s/f you will see a cover .. it pulls off.
I have in the past fitted the ctek lead into that area so you just pull off the cover and plug it in.... a little bit of " fettleing " is required .
At OPC and we just used to have it on the n/s and popping out under the bonnet .. it can fall back in though and no were to fix it with a cable tie etc .
EDIT .. pretty much what phil has said
spongebob squarepants said:deMort said:If you look at the trim panel the wipers go in then n/s/f you will see a cover .. it pulls off.
Yes but in a more understandable way ... :grin:
alex yates said:With regards to a 'free' power source for charging, I was watching this on the news tonight. Amazing invention and I reckon it'll only be a year or two when you'll be able to buy a mini wind turbine that'll churn out enough power to keep your battery topped up:
https://www.independent.co.uk/life-...-generate-electricity-renewable-a8524561.html
alex yates said:Too many trolls and keyboard warriors these days with nothing better to do than nit pick at folk who do stuff. End of the day they're just a set of jealous simpletons.
These lads have really created a masterpiece and the options with their new invention are endless. It's like a propeller that can pull in any direction at any given moment. Totally mind blowing.
James M-S said:I have the cigarette lighter adaptor for ctek, the cable can come out of the door when closed allowing the car to be locked and alarmed.
