997 : 2004- 77
996 : 1997-2005 40
964 : 1989-1993 4
Boxster : 1997- 19
Cayman : 2005- 11
Mark w
PostPosted: Thu Aug 23, 2018 2:55 pm    Post subject: Airbox modification to motorsound Reply with quote
Hi all, I obtained a second hand airbox cover to experiment with as I've seen lots of various opinions on whether a motorsound airbox actually makes much difference (sound wise that is!) so rather than destroy my existing one and regret it today I had a go at replicating the holes in the side (dimensions of which were given by a nice guy on rennlist who has a geniune one)
now before anyone says it, yes I could have gone to the effort of making a nice steel template drilling jig but I thought i'd do it a slighter different way as I wanted to trial it quickly.
So, I did a quick drawing of both sets of holes (one area is larger than the other) and printed the on tracing paper to use as a template, stuck the templates to airbox, centre mark the holes in the airbox (i used a trepan drill point for this) then used a trepan drill (with the aim to eliminate the need to de-burr after) to drill each hole.
it worked quite well and in all took about 40 mins. this weekend I will fit it to see what the end result is IF ANY!.
some pictures below help show the process. Ill be back soon with an update
Mark
 Filesize:  163.44 KB
 Viewed:  2393 Time(s)
 Filesize:  180.96 KB
 Filesize:  209.74 KB
 Filesize:  153.14 KB
 Filesize:  198.14 KB
 Filesize:  289.06 KB
 Filesize:  147.32 KB
 Filesize:  181.54 KB
2014 Porsche Boxster 981
PostPosted: Thu Aug 23, 2018 3:12 pm    Post subject: Reply with quote
But you don;t get the shiny metal edges to the intake which both cool the air (for better induction) and improve airflow Dont know
Joking but they do look nice when you open the engine bay Wink
"Imagination is more important than knowledge" Einstein
#lastoftheaircooled
2014 Porsche Boxster GTS My Journal
Mark w
PostPosted: Thu Aug 23, 2018 3:47 pm    Post subject: Reply with quote
Haha
I know what you mean!
If I can notice the difference in sound then I will probably get the plastic intake chrome plated (metalized plastic that is!) so I can admire each time I open the engine lid
ch3tman
1995 Porsche 993 Carrera 4
PostPosted: Thu Aug 23, 2018 7:40 pm    Post subject: Re: Airbox modification to motorsound Reply with quote
Nice work...!
Interested in your feedback! Smile
1995 911 | 993 C4
Tobesetc
PostPosted: Fri Aug 24, 2018 7:36 am    Post subject: Reply with quote
Also interested in your thoughts/feedback. I've got one of the shiny covers sat on a shelf unused because having a rear wing I elected for the "horn" attachment to bring cool air direct from the louvres in the wing.
Surely, if holes in the air box are a benefit, more holes are more benefit? Then eventually no cover is better than a cover? (Ie, one big hole)
993 C4, Coupe '94 manual
Previous - '03 986 Boxster S
Mark w
PostPosted: Fri Aug 24, 2018 11:35 am    Post subject: Reply with quote
yes I think you are correct as I have seen airbox covers for sale that are little more than a frame (see attached picture), however this means every time you open the engine lid you are confronted with the view of your air filter. I was just trying to keep it look like it would with the factory option but maybe I will open the holes up or even cut the rectangular section of each aperture out to see a better result.
 Filesize:  54.66 KB
 Viewed:  2228 Time(s)
Endoman
PostPosted: Fri Aug 24, 2018 8:59 pm    Post subject: Reply with quote
If you keep the clutch vent pipe it will become useless with a fully open airbox. The only benefit of a motorsound airbox is in the description (sound)
I'm not a fan of snorkels either.
I got rid of the clutch vent pipe, covered the vent with brass wire mess and plugged the airbox hole with the tiptronic plug. I run a motorsound airbox and I nearly jumped out of my skin with the glorious intake roar on wot over 4k rpm.
rogttr
PostPosted: Sat Aug 25, 2018 9:27 pm    Post subject: Reply with quote
Endoman wrote:
........with the glorious intake roar on wot over 4k rpm.
^^^that.
I have a motorsound airbox available for purchase. Hardly used. £80. pm me.
C2S Arena Red.
ch3tman
PostPosted: Mon Oct 15, 2018 10:54 am    Post subject: Re: Airbox modification to motorsound Reply with quote
...what were your conclusions?
1995 911 | 993 C4
Mark w
PostPosted: Tue Oct 16, 2018 1:04 pm    Post subject: Reply with quote
Well I had a good drive to France a few weekends ago, Conclusion was that it really didn't make much difference even when i went through a long tunnel I never noticed a difference in the roar, so I assume like Endoman says i need to get rid of the clutch vent pipe plugged into the airbox.
I'll try this soon and post back on results.
Fulla
PostPosted: Wed Oct 17, 2018 8:18 am    Post subject: Reply with quote
Can I ask what the vent pipe does? Any issue with removing it?
If you have any pictures it would be helpful.
My airbox has the hole modification so I can't comment on sound before or after but I would be interested to investigate if the vent pipe is still active.
______________________
993 C4S
911 3.2 Clubsport
Ex 993 C2
Ex 996 C2
