lethallegend72
- Joined
- 21 Mar 2013
- Messages
- 121
I eventually got my Topgear exhaust from the group buy installed last week.
The Exhaust switching operation only works occasionally...
So far, I have tested the Topgear electronics and solenoid valve and everything appears to be working correctly.
When I bypass the valve and plug the vacuum line directly into the exhausts there still isn't enough vacuum to operate the valves.
I have plugged my vacuum gauge into the vacuum line used by my installer and the Vacuum reading is very low compared to when the system intermittently works. (I will try to upload photos)
So, there are a couple of possibilities.. probably more..
1) The Vacuum point used by my installer is not correct and there isn't enough vacuum unless under certain conditions.. (e.g. valves activated.)
-- Does anyone else have a turbo and can show me where the Vacuum line is connected to?
2) I have a vacuum leak - (my vacuum tester holds a steady vacuum with no loss when testing at the point used for the exhaust tap)
---My car appears to drive ok, steady idle, no engine warning light.
-- Maybe a smoke test would be more appropriate...
Any other ideas??
Any other ideas??
