997 : 2004- 74
996 : 1997-2005 34
Boxster : 1997- 18
Cayman : 2005- 17
PostPosted: Mon Aug 06, 2018 10:02 am    Post subject: GT3 seat brackets Reply with quote
GT3 guru's, I need your help
I put my bucket seat into my car, driver (right) only so I could get the kids in and out. (Not in at present BTW)
They climb over the seats anyway so I thought I may as well put the passenger side seat in too nooo
I have a spare set of rails, easy...
What I seem to have is, and here is the question, two sets of the same brackets. So two pair's of driver side brackets I was told.
Looking at the parts diagrams for seats/brackets, they list a part number for the left bracket and another for the right:
http://www.autoatlanta.com/porsche-parts/hardparts.php?dir=GT31-03-05&section=817-90
item 10.
So I call Porsche parts Silverstone and they tell me that they are all the same. No difference between passenger/driver side brackets. That I just need a pair, which I have.
So who's wrong? Friend who works at OPC or Porsche OPC part's chap? PC
99652192390 Driver side
99652192490 Passenger side
And also this:
99652192393 Adapter Parts Kit Seat Rail Left Seat (LL)
I know that one bracket is a bit 'wider' so it moves you away from the centre console a little, is that the same for the passenger side too Dont know
TIA Thumb
Senoj
PostPosted: Mon Aug 06, 2018 6:42 pm    Post subject: Reply with quote
No direct experience but..
By “bracket” do you mean the sliding rails or the mount (vertical) that fits seat to the rails?
It stands to reason that if the mounts are offset ( not symmetrical) to position the seat to the wheel/pedals ( more likely) then they’ll be handed L/R too. Then there will be the seat belt receptable thingy mount point which is definitely handed so id say OPC are a bit wrong. Add to that there are two distinct part numbers...
PostPosted: Mon Aug 06, 2018 10:06 pm    Post subject: Reply with quote
Thanks for that.
I mean the mount, and I agree, I think OPC are wrong too PC
PostPosted: Sat Aug 11, 2018 8:52 pm    Post subject: Reply with quote
For the viewers at home only...
I have these, Driver side, so if you know the part number then that would be great:
And here is a set of driver side and passenger side next to each other (yellow = Passenger side, blue = driver side), you can see that they are totally different and NOT the same as the OPC parts bloke said:
Answers on a postcard or you can reply here... Grin
