996 : 1997-2005 43
Boxster : 1997- 13
Cayman : 2005- 12
Macan : 2014- 0
Dammit
PostPosted: Sun Jul 29, 2018 7:39 am    Post subject: I like big brakes and I cannot lie Reply with quote
I have been intending on swapping to Girodiscs when my OEM rotors/pads wear down, so to that end I called an Indy who supply them over the weekend.
Total cost, fitted, including VAT would be £3,200.
Which set me to wondering- I’ve used Reylands discs on my old car which had AP Racing brakes, and they offer bells for all cars- if they don’t have your pattern they’ll make some up.
Unless I’m way off base the Girodisc kit is rotors, bells, bobbins, and spacers to move the radial mount calipers outward- 12mm or so.
You’d need pads of course, but looking at the costs on the Reyland site it would appear that this would be a significantly more affordable option.
What have I missed?
http://www.girodisc.com/Rotors_c_1036.html
http://www.reyland.co.uk/discs/
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Sun Jul 29, 2018 7:51 am    Post subject: Reply with quote
The Reyland disks look like good value, how much are the bells and fixings?
Are the rear bells correctly formed for the handbrake?
Dammit
PostPosted: Sun Jul 29, 2018 8:02 am    Post subject: Reply with quote
They don’t show Porsche on the site so I will give them a ring Monday afternoon to discuss.
From their site:
We're also happy to create kits for you using high quality, good condition calipers previously used on other vehicles - popular options being brake calipers from Porsche, Jaguar and Ferrari.
Custom kits : £Call
Bells: £180-£240 pr
Brackets : £250 pr
Dammit
PostPosted: Sun Jul 29, 2018 8:04 am    Post subject: Reply with quote
Brackets would not be needed, I believe- only spacers, although maybe a single spacer for each caliper would be stiffer.
Dammit
PostPosted: Sun Jul 29, 2018 8:05 am    Post subject: Reply with quote
Bolts are £18/wheel
coullstar
PostPosted: Sun Jul 29, 2018 8:28 am    Post subject: Reply with quote
Id be interested as well for sure.
2000 Audi B5 RS4
Dammit
PostPosted: Sun Jul 29, 2018 8:33 am    Post subject: Reply with quote
I was hoping that they were closer and I’d have popped in, but of a way from me though
 Filesize:  605.85 KB
 Viewed:  2686 Time(s)
Dammit
PostPosted: Sun Jul 29, 2018 9:16 am    Post subject: Reply with quote
Just putting this here so I don't forget (and this may be wrong!) Girodisc front spacers 12mm rear 14mm.
PostPosted: Sun Jul 29, 2018 1:24 pm    Post subject: Reply with quote
Best thread title ever!!!
PeterS
2003 Porsche 996 Carrera 2
PostPosted: Sun Jul 29, 2018 1:59 pm    Post subject: Reply with quote
Yeh, 20 miles from me as well. 😄
crash7
PostPosted: Sun Jul 29, 2018 2:08 pm    Post subject: Reply with quote
I run Giro Discs, front & rear. - They are excellent and made a marked difference over standard - I track and had previously considered a big brake conversation, however standard callipers, RS29, Giro, GT3 Ducts and RBF660 are more than up to prolonged use.
If you want pictures, measurements or info let me know.
Are you looking to copy the Giros? The reason I ask is that when my rotors need changing it would be good if I could source locally and re-use the Giro bells.
asterix_the_gaul
1999 Porsche 996 Carrera 2
PostPosted: Sun Jul 29, 2018 2:18 pm    Post subject: Reply with quote
Dammit, the 3.2k Seems a lot of cash compared to a ksport/ D2 bbk setup which is cheaper and you get new calipers discs bells pads lines, etc all round
Dammit
PostPosted: Sun Jul 29, 2018 3:18 pm    Post subject: Reply with quote
Thanks for the offer- that’s really handy.
I’m interested in whether the best route is to import this stuff from the US or whether a U.K. supplier can come up with the same stuff.
It may be that I end up buying Girodiscs when I’m in the US next, but the FX situation doesn’t make that the great idea it used to be.
I like the idea of keeping my calipers- I’ve just had them refurbished- and I have GT3 ducts, so the floating rotors and caliper standoff’s seem a good way forward. £3,200 simply strikes me as a lot.
crash7
PostPosted: Sun Jul 29, 2018 6:20 pm    Post subject: Reply with quote
I bought in the US. - Should you want details PM me.
Fitted myself, very easy, all in cost was circa £1500, which was palatable, particularly as I am very pleased with the performance.
As a side note they also look better, as they are physically bigger, and they weigh less than standard discs.
£3200 however is a big chunk of change.
Dammit
PostPosted: Mon Jul 30, 2018 11:40 am    Post subject: Reply with quote
I spoke with Reyland- £550/axle.
rdodger
PostPosted: Mon Jul 30, 2018 1:21 pm    Post subject: Reply with quote
That sounds like good value. Does it include bells, rotors, bolts and spacers? Excluding VAT?
Dammit
PostPosted: Thu Aug 02, 2018 3:39 pm    Post subject: Reply with quote
Ok, got an update on price and a front and rear disc have been sent to Reyland (thanks Martin!)
Front discs bolted will cost £550
Front disc’s fully floating will cost £700
Spacers and bolts for above conversion £60
Plus Delivery of £15
Rear Disc with Hand brake hub
Bolted rear disc, £580
Fully floating rear disc, £730
And an as yet unspecified discount available if you get both front and rear.
Dammit
PostPosted: Thu Aug 02, 2018 3:40 pm    Post subject: Reply with quote
Replacement discs would be £275/axle thereafter.
Question I had - do people with Girodisc use a slightly larger pad?
crash7
PostPosted: Thu Aug 02, 2018 6:30 pm    Post subject: Reply with quote
No, same calipers same pad size.
Dammit
PostPosted: Thu Aug 02, 2018 7:16 pm    Post subject: Reply with quote
What pads are you running?
