Hi all just did an oil and filter change snd managed to snap a coolant pipe.
The fill tube had come away from the pipe so i was trying to reattach it and a thin coolant hose next to it broke sending coolant spraying out all over the place. The bit thats broke is a connector right next to the oil fill pipe. Does anyone have any idea what the part is? Is it easy to replace and would it just be a case of retopping up the coolant once its repaired? Thanks in advance. Also i assume its not worth trying to start the engine with this bit not connected?
