my horn is feeble
slackster
16 Jul 2013
352
so...
on a cruise today i noticed my horn sounded like a kids bugle instead of the normal sound i recall it made.. any ideas what has busted ?
is it as simple as a horn change or is there anything i can check to get my horn all manly and large again?
:lol:
Common fault fella, you have lost one of the horns, they are situated in a crap position where they get a load of ***** thrown up at them, new one was 40 odd baht from Opc.
There is a low tone and high tone horn, cannot remember which of mine had expired had to buy a modified wiring loom section also which was quids if I remember.
Ah.. so its 2x horns and one has died, gotcha
ok so is it an easy fix that I can do? i assume my low tone one has died.
cheers for the info though !
:thumb:
Drivers side wheel arch liner out if I remember correctly , as said a common 997 thing.
Yep, told mine has gone. Never use it and one gives MOT pass, so not sure I can be bothered to fix it
I was able to access mine below the bumper, rather than remove the arch liner.
Cheers guys,
I can see ECP do them for £45ish, I'll have a look at how hard it is to get access to this weekend.
:thumb:
I think Porsche were about that and included the loom adapter.
Seems you have already been given the correct advise to I will save my Viagra joke :floor: :floor: :floor:
If you have a center rad then its PU off .. if not it can be done by undoing a few screws on the underside and pulling down the PU enough to get access.
Either way its a straight forward job .
124,590
1,441,835
49,019
andrew bulloch7
