Oil found on inner front left wing - any ideas
P911X50
Nurburgring
3 Jan 2017
421
Hi
I've found oil on the inside of my nearside front wheel. Any ideas what this could be? :dont know:
is it very thick, almost tar like ? if so probably split CV boot.
If so its the grease from the CV joint being thrown out through the split
Split cv boot usually leaves a ring of grease around the inside perifery of the alloy.
Is it a tip? Doesn't the tip have an oil rad up front? My 850i once sprung a leak like that and it was the oil pipe from box to rad.
You've got AC pipes there as well which can look wet if they spring a leak although doesnt really look oily.
Thanks Folks,
The oil/fluid starts from right from very the top of the suspension mounting/shock absorber, there was a rubber nipple, I recall, could that be the culprit?
I did check the rubber gaiter and they all seemed fine. Hope this helps?
I've also remember noticing that it has taken off some paint. Possibly brake fluid or maybe Pentosin?
Sounds like your n/s/f shock absorber is leaking .. fluid will come out from under the bellows or below the bump stop .. lift bellows and take a picture if possible for us to confirm .
If a brake fluid leak then you need to get it checked asap .. the pedal should be soft by now .
Also as mentioned .. brake fluid is corrosive .. you dont want it on any paintwork !
Some pictures please :)
Thanks,
I'm back home on Wednesday night. I do remember the front knocking a little when driving over speed bumps. Is the fluid in the shocker corrosive?
I will post pics Thursday morning
Im not sure im afraid .. i dont think so , it doesnt really spread that far to reach the bodywork .. brake fluid is if left on paint work .... but if it was that i think you would have very poor brakes by now .
I don't know as Damper fluid isn't something you really come into contact with but they are both hydraulic fluids so I wouldn't risk it - wash it off well with plenty of detergent, ideally I would use my pressure washer.
Hi
As promised. please see picture from nearside front. I had steamed cleaned and painted the inside wing, removing wheel liners etc. So it was very clean before this appeared. Any ideas where this is coming from?
124,588
1,441,799
49,014
mwarren1
