Cazana quoted £12,923 can`t be bad just need to try and get that now.
It has had one or two little jobs completed under my ownership:
Porsche 996 K70 ACW service record.
Minor service - 13th June 2015 @ 86,146 miles.
Rear Tyres (Accelera PHI ZR) replaced - 13th June 2015 @ 86,146 miles.
Clutch, Dual Mass flywheel & clutch slave cylinder replaced - 13th June 2015 @ 86,146 miles.
Radiator header tank cap replaced - 5th July 2015 @ 86,474 miles.
Fuel flap latch components replaced - 5th July 2015 @ 86,474 miles.
Spark plug tubes & seals replaced - 7th July 2015 @ 86,560 miles.
Ignition coils replaced – 7th July 2015 @ 86,560 miles.
Spark plugs changed (NGK BKR6IX Iridium) - 8th July 2015 @ 86,560 miles.
Headlights (H7 dipped beam) converted to HID, side lights to LED - 9th July 2015 @ 86, 563 miles
N/S Camshaft Variable solenoid cap & seal replaced - 11th July 2015 @ 86.567 miles.
N/S headlight mounting tray replaced – 14th July 2015 @ 86,570 miles.
Fuel door hinge replaced -14th July 2015 @ 86,570 miles.
Front alloy wheel (BBS Sport Classic 2) replaced – 23rd July 2015 @ 86,636 miles.
Front tyres replaced (Bridgestone S-02A N3) – 23rd July 2015 @ 86,636 miles.
Exhaust tail pipes replaced (Turbo stainless dual pipes new clamps) – 23rd July 2015 @ 86,636 miles.
Wind deflector mounting clips in rear interior panels fitted -24th July 2015 @ 86,636 miles.
Soft top hydraulic fluid replaced – 24th July 2015 @ 86,636 miles.
Anti-freeze @ 50% replaced – 1st August 2015 @ 86,750 miles. (Triple QX Red – 5 year life)
Cabin air filter replaced – 27th August 2015 @ 86,795 miles.
Transaxle oil changed (Triple QX 75w 90 full synthetic) – 19th September @ 87,198 miles.
Front bumper removed and debris cleaned from radiators/air condition heat exchangers – September 27th @ 87,225 miles
Front and rear drains (rear for soft top) checked and cleared of any debris – 10th October 2015 @ 87,375 miles.
Remote key head part number 996.637.243.00 replaced – 21st October 2015 @ 87,600 miles.
Indicator flasher relay replaced with electronic type – 18th January 2016 @ 88,532 miles.
2nd Remote key head part number 96.637.243.00 replaced – 19th January 2016 @ 88,536 miles.
Side Decals added - 5th February 2016 @ 88,587 miles.
Rear spoiler switch added to dashboard – 10th February 2016 @ 88, 587 miles.
Front brake caliper pipes & brake fluid replaced – 5TH June 2016 @ 89,693 miles.
Rear tyres replaced (Bridgestone S-02A N3) – 6TH June 2016 @ 89,693 miles.
Alternator replaced (150 Amp) – 15th August 2016 @ 90,049 miles.
Auxiliary drive Poly Belt 6PK2115 replaced – 15th August 2016 @ 90,049 miles.
Ignition switch replaced (4A0 905 849B) - 12th December 2016 @ 90,800 miles.
Starter motor de-greased & brush pack and Oilite bush replaced – 6th January 2017 @ 90,902 miles.
Catalytic converter to exhaust box coupling studs replaced with new gaskets and stainless steel 8mm nuts & bolts - 8th April 2017 @ 90,336 miles.
Drivers window regulator and motor replaced – 29th April 2017 @ 91,470 miles.
Timing Chain tensioners replaced – 51st May 2017 @ 91,599 miles.
Sump plug replaced (magnetic) – 31st May 2017 @ 91,599 miles.
Engine Oil & Oil filter changed – 31st May 2017 @ 91,599 miles (Comma Synergie 5W- 40 full synthetic)
(FRAM Oil filter – CH10512E)
Power steering pump fluid changed - 14th July 2017 @ 92,055 miles (Comma MVCHF )
Bonnet hydraulic struts replaced – 26th November 2017 @ 92,606 miles.
N/S front brake pad wear sensor replaced – 12th May 2018 @ 93,109.
Del.
