I think I have tracked down my steering squeak to the near side top mount and bearing area. Sprayed in some lube and now only have a slight click when rocking the steering wheel. My question is can these be changed without the need for removing the strut from the car. I have H&R springs so the springs are shorter? is there sufficient clearance to replace the parts once the damper rod nut is released etc anyone done it this way?
