My car has been in the Porsche workshop having every nut and bolt replaced from the exhaust manifolds all the way back including the Turbo mounting bolts , this was because of excessive corrosion. Sines then I have noticed a high pitched whooooing noise when I back off the throttle, so the turbos kick in and the when I lift off I get this short whoooooo noise. I can't say I have ever noticed it before but I wondered if the mechanic has replace or adjusted something that may have caused it. The only other thing that was done was the rear suspension bushes but can't see that causing this. Anyone have any ideas?
Is it normal?
Is it normal?
