991 : 2011- 20
997 : 2004- 78
Boxster : 1997- 25
acamp76144
PostPosted: Fri Apr 27, 2018 10:08 pm    Post subject: Dashcam Reply with quote
I’m looking to fit a discrete dashcam and am considering a blackvue dr750s. Has anyone else got one fitted?
I wonder why they aren’t oem options these days and housed in the back of the rear view mirror display? You can option pretty much anything else!
Current: 991 4S, 993 4S
Previous: 997 4S
Next: 992 GT4S
rigsby99
PostPosted: Sat Apr 28, 2018 5:53 am    Post subject: Reply with quote
The vantrue N2 looks very similar but much cheaper, Amazon
Magic919
PostPosted: Sat Apr 28, 2018 6:23 am    Post subject: Reply with quote
I think it’ll be a while before these are a factory option at Porsche. I have a Ford that has a camera, with an option to fit two more and none of those will work as a dashcam.
I use DDPai cameras that Techmoan recommended a while ago. They have no screens and are fairly discreet.
997.2 C4S PDK
timm996
PostPosted: Sat Apr 28, 2018 6:24 am    Post subject: Re: Dashcam Reply with quote
acamp76144 wrote:
I think its one of two reasons, the techno of constant recording into sd card is not foolproof and they dont want a lawsuit that it missed an accident. Also it could be seized by police as evidence if mandatory. Its always easier to say it wasnt on or broken or hide the card its stuck on a screen.
Sulz
PostPosted: Sat Apr 28, 2018 8:23 am    Post subject: Reply with quote
DDpai looks good, I want a dash cam without the screen. Would prefer a smaller discreet unit in lieu of a screen. Did you install yourself? Powered from USB in glovebox or wired into fuses?
991 Carrera
958 Cayenne
451 Smart Car
FRZ 911
2007 Porsche 997 Carrera 4S
PostPosted: Sat Apr 28, 2018 8:59 am    Post subject: Re: Dashcam Reply with quote
acamp76144 wrote:
I have an older version fitted to my car and wired through a Pro-Magic box into the fuse box. This means the camera is on a constant supply for when the car is left but comes out of parking mode when the ignition is turned on. The Pro-Magic also monitors the supply so, if the battery voltage drops too low then it disengages the camera.
The Blackvue unit does exactly what it says and well imho and has been faultless for over 5 years of use. I placed mine in front of the rear view mirror (I don't have a rear facing camera fitted) which is invisible to the driver and well hidden when looking outside. I've attached a picture.
The power wire can be tucked into the edge of the roof lining and driver's side A pillar down to the fuse box.
Hopefully of use.
All the best.
997.1 C4S Meteor Grey Manual
 Filesize:  1.19 MB
 Viewed:  2999 Time(s)
Magic919
PostPosted: Sat Apr 28, 2018 10:45 am    Post subject: Reply with quote
Yes, DIY fit. Tuck the wire in around the windscreen. I use 12V socket in the footwell via adapter to USB. That’s the easy route on a 997 that has no USB in the area.
997.2 C4S PDK
Sulz
PostPosted: Sat Apr 28, 2018 1:47 pm    Post subject: Reply with quote
Brilliant , have ordered one on amazon prime so will be here tomorrow , will install then too.
991 Carrera
958 Cayenne
451 Smart Car
