Hi guys, I've little time to research right this second so I need a little help. Replaced my Oil pressure sensor last night due to what I hoped was an oil pressure indication problem. Nil fix. I decided to drive the car to work this morning just to check if it could simply potentially be an indication problem:
-oil px sits basically at 2BAR cold and doesn't change a great deal. When driving up to 4000rpm, oil px just drops slightly sometimes to 1BAR.
No abnormal unusual sounds but I have had a noise for some time so could be related.
My feeling is the oil pump is faulty. My question is; is this likely? from memory I've never heard of one failing before on a 996.
I did have a strage noise the other day following a start up with no oil px showing then a sudden rise but only to 2BAR. This was the first time this fault poped up. I think I best drive home carefully tonight and whip the oil pump off... Looks like Dinslaken in the 996 is off the cards :sad:
