Just wanted to post about a frustrating noise coming from the rear left brakes when cold. When I pull away there is a scuffing noise which I can get rid of by applying the brakes on and off, cycling the handbrake and usually disappears when the brakes get warm.
I have raised with my OPC as my car is under warranty and was told sometimes some grit, debris gets on the disc and usually hard braking will resolve. Having tried this numerous times and having had the discs changed at the rear reasonably recently, I wondered if anyone had any sensible suggestions or suitable resolves?
Initially I thought it was the tyre catching but it's definately related to the brakes. Thoughts gratefully received.
