So I am going through a bit of a love in for my car currently. 60,000 miles has just ticked over and I'm doing some preventative maintenance stuff.
So -
RSS Engine Mounts
HEL Performace Braided Brake Hoses
Top Gear 200 Cell Sport CAT 63mm (this is the final bit after replacing the mufflers and manifolds a couple of months ago)
While I'm at it I am going to change the pads and brakes. They are worn through but I hate the car being spoilt by worn looking discs and the rust that accumulates as a result. I may also be changing the brake lines at the same time as these are a item that rusts - mainly round the clips - so it makes sense.
All in all around £2500 of stuff.
My garage, GCR, has recommended Sebro over OEM discs and pads. He, that is Chris who I really like, says that they are better than Brembo and much better than OEM. I trust him but would like some other opinions before I fist the kumquat.
PS - also is there any value in the old discs and CAT???
(yes this is also posted on PH)
So -
RSS Engine Mounts
