Hi, bit of detailed post follows, looking for some :help: please.
I am in the market for a new set of wheels as I have an out of round issue that cannot be balanced out. The current wheels are 19" 8j ET57 front and 11j ET67 rear, shod with 'standard' 235/35 and 295/30 tyres respectively (car is narrow body - gen 1 C2S).
I have 15mm spacers rear and 9mm front.
I fancy the fuchs style (not original as too expensive ) - car is black so should look like the example below . Design 911 have them at £1134 (inc VAT) and the same (as far as I can see) are on ebay at £1035 and £590, (the latter state as made in China). All of these three are 8.5j ET55 front and 11j ET55 rear. Some pictures below.
A bit of research on offsets and some sketching has led me to conclude that the fronts, being a wider rim and less offset, and with no spacer fitted, will be 0.6mm narrower on the car than mine are today - so fine. The rears will need a 3mm spacer to be exactly the same (and as it happens I already have 3mm spacers from a previous experiment).
So far so good. . . .
The fronts can take my 235/35 (so wall height = 70.5mm) but being 8.5j can also take 245/30 (so wall height = 73.5mm).
So, my questions are:
1) will the 235 look ok on the wider rim or should I go 245/30 assuming that a 3.5mm ride height increase (when new) is negligible?
2) The wider fronts will be 4.5mm wider in the wheel arch (towards the car centre line) - I am assuming this is negligible (catching on full lock?).
3) £590 has my "too good to be true" alarm bells ringing - although they ship from Basildon?
Any views appreciated - especially if my maths is wrong
:eh!:
thanks
:eh!:
thanks
