Alfaian said:
kurlykris said:
A decent trolley jack will be fine to hold a corner up for a few hours, it`s not like you`ll be underneath the car, I tend to put a few blocks of wood under the wheel carrier as extra security, just incase disaster strikes :thumb:
Chock the front wheels when you work on the rear wheels/arches, just to be sure and leave the car in 1st gear all the time you`re working on it :grin:
I always leave my cars in 1st gear when on the drive..............I had one escape when the brakes cooled down after a spirited drive and the handbrake didn`t hold...............was woken at 5am by plod as the car was parked accross the road, blocking the whole cul de sac :eh!:
Top advice this :thumb:
Same happened to an old Alfa I once owned except the car was lying up against someone's garden wall
My daughters car did this on a warm day not long after she passed her test , parked outside her Grans house .....glanced out the window at a car 'just like hers' rolling down the road with no driver ... stopped in the neighbours wall though ...£500 repair paid for by Bank of Dad......ouch....
On topic...always have a reserve support under your car to support in case of the unlikely....
Would be wise to purchase an extended wheel wrench to get your wheel nuts off...torque wrench is for checking torque on tightening the bolts, use the normal wrench until hand tight....
I recommend a race height jack and rubber pucks to shim up to the jacking points.SGS do an excellent range
https://www.sgs-engineering.com/tja25-aluminium-trolley-jack
I bought jackpoint jack stands but haven't used them in anger yet ...
http://www.jackpointjackstands.com/
They are a great idea if you are planning a lot of use though .....second to none imo...
I always use a stud extension guide while removing or replacing wheels , sometimes 2 , makes like much easier and safe
https://m.youtube.com/watch?v=o6dc5YCxua8
