996 : 1997-2005 43
Boxster : 1997- 13
Cayman : 2005- 12
Macan : 2014- 0
wasz
1999 Porsche 996 Carrera 2
PostPosted: Fri Jun 22, 2018 7:20 pm    Post subject: Reply with quote
Interesting to hear that about the Konis
You don't hear of many people fitting them to 996
My special order Vesuvious Charcoal 996 | Clutch, Fly RMS IMS AOS Job |
coullstar
PostPosted: Fri Jun 22, 2018 9:33 pm    Post subject: Reply with quote
I was eyeing up these so good to hear. Did you fit the Vogtland springs in the end?
How much was the drop?
2000 Audi B5 RS4
blanc
PostPosted: Sat Jun 23, 2018 9:51 am    Post subject: Reply with quote
The Koni Special Active are just released for the 996. I did fit the springs. Approx 1" drop, very similar to a M030 ride height
blanc
PostPosted: Mon Jun 25, 2018 11:47 am    Post subject: Reply with quote
Thinking of refurbishing my original wheels but changing the colour. Any suggestions ??
Stotty
PostPosted: Mon Jun 25, 2018 1:56 pm    Post subject: Reply with quote
Which springs did you fit with the Koni's?
I'm looking at suspension options for mine... I read somewhere that FSD's aren't suitable for use with lower springs, but sounds like your happy with yours.
I want to go -30 f&r.
2000 996, C2, manual, arctic/metropole, sunroof delete, Koni shocks, H&R -30 spring, Cup wheel, 170k miles. 2018 Touareg RLine Plus
blanc
PostPosted: Tue Aug 28, 2018 1:35 pm    Post subject: Reply with quote
Hi
The new Special Active (FSD) ARE SUITBALE FOR LOWERINGS SPRINGS! I used Vogtland Springs
blanc
PostPosted: Tue Aug 28, 2018 1:47 pm    Post subject: Reply with quote
Some updated Photos
 Filesize:  464.24 KB
 Viewed:  1483 Time(s)
 Filesize:  145.39 KB
 Filesize:  364.08 KB
 Filesize:  551.39 KB
 Filesize:  213.94 KB
911munKy
PostPosted: Tue Aug 28, 2018 3:05 pm    Post subject: Reply with quote
Would you mind giving a review on the ride quality of the Koni FSD damper and Vogtland spring combination please, we’re you on standard suspension before? Are the Vogtland spring softer or stiffer than standard?
Any trouble with ground clearance or geo alignment now that you are 30mm Lower?
2000 C2 996
Hooner
PostPosted: Tue Aug 28, 2018 5:31 pm    Post subject: Reply with quote
great pics Thumb if you're ever up the northcoast giz a shout thumbsup
911 a way of life!
blanc
PostPosted: Tue Aug 28, 2018 6:07 pm    Post subject: Reply with quote
Thanks guy's, The FSD (Special Active) have transformed the car. Have used standard and Bilstein PSS10S . They lower the car about 20mm on the Special Active shocks. It is more comefortable than standard yet stiffen up when driving hard. It blew me away, Bilsteins are just about unusable on the country roads where I live
jezgreen911
PostPosted: Tue Aug 28, 2018 8:58 pm    Post subject: Reply with quote
Cars looking great Thumb
I am also pondering over suspension options, good to read your positive review of the Koni's, I was unaware that the Special Active's were suitable for lowering springs, that gives me another option thumbsup
2003 996 C2
coullstar
PostPosted: Wed Aug 29, 2018 8:04 am    Post subject: Reply with quote
I think they do but only for M030 or less i.e. a 10-15mm drop from std.
Im going the yellow TA ones as Ive found them very good in other cars.
2000 Audi B5 RS4
blanc
PostPosted: Thu Aug 30, 2018 5:20 pm    Post subject: Reply with quote
25mm drop is aok from standard with the new FSDs. Once the car was properly aligned and setup it is magical. I used a race shop to do corner balancing plus alignment
blanc
PostPosted: Sun Sep 02, 2018 9:46 pm    Post subject: Reply with quote
Looking for a carbon ducktail and a C4s front bumper if anyone knows of something suitable
911munKy
PostPosted: Mon Sep 03, 2018 6:47 am    Post subject: Reply with quote
I’ve been looking at the 996 VOGTLAND springs and they give a 30mm drop over standard suspension according to their brochure.
I also thought that you could only corner balance a car with adjustable ride height adjustable coil overs which I didn’t think the Koni’s were.
I stand by to be corrected.
2000 C2 996
blanc
PostPosted: Mon Sep 03, 2018 1:15 pm    Post subject: Reply with quote
The Konis are adjustable, they have to be done when off the car. I use adjustable drop links to help setup the car. It took a full afternoon to properly setup the car.
blanc
PostPosted: Sat Sep 08, 2018 7:53 pm    Post subject: Reply with quote
Does anyone here have experience using a bigger throttle body and plenum on the 3.6? I would appreciate any feedback.
NLW73
PostPosted: Sat Sep 08, 2018 8:46 pm    Post subject: Reply with quote
Minimal change on its own. Will change the drive of the car on the road and may make it worse
You will need to sort the cats as well as get a Remap to get the most of it and to have better flow
997 C2s Schwarz
blanc
PostPosted: Sun Oct 28, 2018 12:39 pm    Post subject: Reply with quote
Some new parts to be installed over the winter.
Carbon GT3 bumper and Carbon Ducktail
New shifter with upgraded bushings
New pads
Upgraded Sway bars
3rd rad and low temp thermostat and new water pump and belt
Eibach adjustable front control arms
LSD
alfazagato
PostPosted: Sun Oct 28, 2018 4:32 pm    Post subject: Reply with quote
As I said before "Blimey there's not much left of the original car left after all this work!!" Best of luck and I hope that the changes make driving life better. Please let us know.
Page 2 of 3
