996 : 1997-2005 43
Boxster : 1997- 13
Cayman : 2005- 12
Macan : 2014- 0
DRZ911
PostPosted: Fri Mar 23, 2018 6:09 pm    Post subject: Reply with quote
david_yorkshire wrote:
Fault report:
One of the camshaft followers on bank 2 (right) has a flat spot with a corresponding wear mark on the bank 2 camshaft
From past experience on a similar problem, this is probably not an inherent material failure but rather a design issue related to insufficient lubrication between the surfaces.
991 Gen 2 GT3 Racing Yellow
Yamaha R1 and BMW R100RS
Diggermeister
PostPosted: Sat Mar 24, 2018 11:02 am    Post subject: Reply with quote
Bigfra wrote:
I have some sexy European S355G10+M plate if you fancy it mate Grin
In the mid 90's, we began using a sub-contractor in South Korea who was making parts for Daewoo (now Doosan) excavators. The component was a design we'd made in the UK (in EN19) and sold successfully for several years. We had component failures, due to brittleness after induction hardening, so we sent the parts for analysis at a lab in the Black Country. The failure was due to inclusions, irregularities.neffectively lower quality steel.
However, they also reckoned the alloy differences were making the components more brittle. Very minor changes in elements like silicon and manganese make significant differences.
Another Korean manufacturer, Samsung (now Volvo) began to have component failures from a part sourced from the same factory. By this time, not only had we predicted this, but we had also pre-empitvely made a batch of parts, in the UK, from European steel, which sold out.
We are still seeing reports similar failures on (presumably now Chinese or Indian) components. All of our manufacturing is not only UK now, but also in house. We have zero reported failures...
david_yorkshire
PostPosted: Fri Mar 30, 2018 7:28 am    Post subject: Reply with quote
just to conclude the thread;
new engine fitted by OPC Cambs; pretty quick too - they must be getting faster Very Happy
Lets see how long this one lasts.
Interestingly, the last two both failed just before the service was due; over long intervals ? who knows..
Right - whens the next trackday ?!
Floor
G2
PostPosted: Fri Mar 30, 2018 7:37 am    Post subject: Reply with quote
Floor
997 Gen2 Turbo S - Speed.
991 C4S - Riviera.
Gazc2
PostPosted: Fri Mar 30, 2018 8:26 am    Post subject: Reply with quote
I like your positive approach David best of luck and enjoy Thumb
2007 997 Turbo & 924s in progress
1990 964 C2
1989 3.2 targa
1987 3.2 Cab
1986 3.3 Turbo
david_yorkshire
PostPosted: Fri Mar 30, 2018 8:43 am    Post subject: Reply with quote
its not really the end of the world, is it ?
All handled seamlessly by the OPC, and I get a new Cayman S to rag around for a week or so.
Car will be in for an interim service next month !
911UK
Porsche Community
Porsche Community
1997 Porsche 993 Carrera 2
PostPosted: Fri Mar 30, 2018 10:23 am    Post subject: Reply with quote
did they advise what engine update you have been fitted with ?
keep us posted on this engine journey thumbsup
Get a Porsche Car Insurance Quote
FOLLOW 911UK ON FACEBOOK
DynoMike
2003 Porsche 996 Turbo
PostPosted: Fri Mar 30, 2018 11:36 am    Post subject: Reply with quote
The problem is a lubrication failure, without doubt. When cams are designed, the designer has to calculate Hz stresses between the lobe and follower, which essentially calculate the lubricant thickness vs load/area.
IMHO. the fact that the tappet clearance is by hydraulic not mechanical means, it follows that the cam/follower contact patch never gets a rest, i.e., there is always contact which prevents lubrication. So... that may be a contributory reason for Porsche going mechanical on the later 991.2 engines.
I'm surprised that a specific oil has not been advised for these engines, or at least an additive package.
Just my 2p
Mike
2003 996 Turbo
Previous toy 1974 Mini 1000
david_yorkshire
PostPosted: Fri Mar 30, 2018 11:44 am    Post subject: Reply with quote
possibly not;
I've found out that the 'G' series engine is NOT the guaranteed solution to the DLC issue; Only G05374 engines and above are 'fixed'
My G series that has just been replaced was G01293; and failed.
I dont know (yet...) what the engine number of the new engine is.
David
squelch
PostPosted: Fri Mar 30, 2018 2:57 pm    Post subject: Reply with quote
Does anyone know if the engine failures / problems also affected the 991.1 GT3 RS models too? (apologies if this has already been asked / answered)
From Stuttgart: 997 GTS, 996 C4S
From Munich: S54 & S50 M Coupes, 535d M Touring, and a couple of bikes from Italy and Germany
david_yorkshire
PostPosted: Fri Mar 30, 2018 4:33 pm    Post subject: Reply with quote
apparently not
seanyboy
PostPosted: Fri Apr 06, 2018 12:32 pm    Post subject: Reply with quote
Has this affected a lot of cars? I’m guessing it’s not down to higher miles or a heavier right foot, I’m in the market for a gt3 and wondering if this should be putting me off!
Disco
Estoril
2010 Porsche 997 GT3
PostPosted: Fri Apr 06, 2018 5:40 pm    Post subject: Reply with quote
It has affected enough cars to be a genuine concern and quite a few cars have had multiple engines, but should it put you off? For me that would depend on whether you were planning to change it from stock spec or keep it for long enough for it to be beyond the reach of warranty cover. For me personally I wouldn't entertain running one outside of factory warranty.
There is also an edge case to consider - I once met someone who (when the car was only a couple of years old) had experienced issues that had already caused them to have to abandon 3 separate European track day trips. When I met them their plan was to get it fixed and then git rid of it as they had had enough.
BUT
Meanwhile there are still plenty of people who have had them for ages, extensively used for intended purpose and who say that they have never had any issue.
So it is a bit of a dice roll really. But if you view the warranty as a running cost then that it isn't necessarily a bad bet.
Or you could just go 996/997... Cool
Colin
Black 997 GT3 3.8 CS - Acquired for the 2012 season and beyond
Black 996 GT3 Mk2 - Gone, but will never be forgotten
DRZ911
PostPosted: Fri Apr 06, 2018 5:48 pm    Post subject: Reply with quote
possibly not;
I don't know (yet...) what the engine number of the new engine is.
David, did you ever get your new engine number and is it after G05374 Question
Diggermeister
PostPosted: Tue Apr 10, 2018 7:34 am    Post subject: Reply with quote
You have to remember that, counterintuitively, the 991.1 Gt3 revs higher than the RS; 9,00rpm, vs. 8,800.
There are other differences to the engines too. I am not saying the higher rev limit is the cause of the issue, although of course higher valve train speeds will not be helpful where another problem already exists.
More about the RS engine here: http://www.evo.co.uk/porsche/911/gt3-rs/page/0/2
I don't buy the lubrication explanation. To me, that would affect more cars (all of them surely?) if it were the principal cause. I'd guess a mechanical/metalurgical deficiency or variance in components is the cause.
Goto page Previous  1, 2, 3
Page 3 of 3
