997 : 2004- 76
Boxster : 1997- 16
Cayman : 2005- 18
matt_SM
PostPosted: Sat Mar 17, 2018 3:49 pm    Post subject: M&M Exhaust Fitting Reply with quote
Whilst fitting my shiny new exhaust I decided to embark on a mini clean up, which mostly involved cleaning up grubby areas and replacing tatty fixtures, fittings and heat shields. I don't have access to a media blaster, so this is not a Mark style clean but more preservation and grime removal!
Examples of grubbiness;
One afternoon of allowing my wife to enjoy the TV remote.
M&M system with additional X-pipe silencers.
matt_SM
PostPosted: Sat Mar 17, 2018 4:01 pm    Post subject: Reply with quote
A little clean up down under (ooh er) revealed RSS toe links and poly bushes attaching the anti roll bar.
The drop links were removed (and replaced) but the roll bar was simple given a thorough degreasing with all fixtures throughly cleaned and or replaced.
Rear light alcoves were degreased, cleaned and smeared lightly with WD40.
matt_SM
PostPosted: Sat Mar 17, 2018 4:13 pm    Post subject: Reply with quote
Bumper brackets were cleaned and painted with satin black
The wheel arches and surrounding bodywork (under the heat shields) were degreased, cleaned and waxoyled. I am not ecstatic the waxoyl finish to be perfectly honest but it will do the trick in protecting the metalwork until such point that I explore more professional options;
Rear wheels cleaned and waxed with wheel sealant
New manifolds fitted with OEM Porsche gaskets and studs
heat shields and back boxes fitted
And finally my trainee is assisting me to align the bumper and M&M tailpipes.
That's about it for now. I've had to replace some tools along the route including a smaller torque wrench for improved access but it has been a lot of fun despite the very cold evenings in the garage!
I am also justifying the cost of the M&M exhaust to my wife on the back of reduced labour costs Thumb
I hope you enjoyed the pictures - I only wish I took more.
Matt
JJT
PostPosted: Sun Mar 18, 2018 10:14 am    Post subject: Reply with quote
Excellent work.
markturner1960
2003 Porsche 996 GT3 Mk2
PostPosted: Wed Mar 21, 2018 4:17 pm    Post subject: Reply with quote
Nice work Matt, its very satisfying work! I am also impressed at you undertaking it all yourself ! No grief with the exhaust manifold studs then? 4 of mine were seized in and needed helicoiling, ......
Did not realize yours was speed yellow as well! The best colour.... Wink
996 Mk2 GT3 Speed yellow
matt_SM
PostPosted: Wed Mar 21, 2018 5:50 pm    Post subject: Reply with quote
Cheers Mark and JJT.
To be perfectly honest I wouldn't have tackled the manifolds, were it not for the fact that Paul Stephens had removed (the DesignTek) and replaced (the OEM) exhaust in entirety when I bought the car.
The silencers hangers were a bit fiddly - I could have used some child labour to reach into the tighter gaps!
It was an enjoyable process because I took my time and as such I could clean away to my hearts content.. Preaching to the converted!
Agreed it's a ray of sunshine and it always makes me smile
Very Happy
Roll on sunny days.
