I have been trying to identify where this oily fluid is coming from with not much luck the two common areas I see mentioned are Diff seals-mine are bone dry,clutch slave cylinder on way out overflows from reservoir above this has also been changed last year. so you can see the oily residue on the two clips on the large pipes this is the only evidence I can find.
does the power steering fluid come from the main fluid tank in the engine bay or is there an additional reservoir somewhere
I know someone will have the answer :thumb:
