996 : 1997-2005 48
993 : 1993-1998 6
964 : 1989-1993 5
Boxster : 1997- 15
Cayman : 2005- 17
Cayenne : 2003- 7
Macan : 2014- 3
912-914-924-928-944-968 3
MMT
PostPosted: Tue Mar 13, 2018 8:19 pm    Post subject: Aircon drain Reply with quote
996 C4 - where is the Aircon condensate drain?
I’ve noticed a few drips approximately where the front passenger side radiators is. I’ve had a taste and it seems like water to me, no antifreeze.
Shanghai
PostPosted: Tue Mar 13, 2018 8:23 pm    Post subject: Reply with quote
N/s and roughly behind the front n/s/f wheel and close to the center of the car .
Look inside the car and its left side on the center consol and about 1 foot back from the bulkhead .
Its not under the n/s/f radiator .
that could well be washer fluid though .. even more so if you have head lamp washers .
At an Indy these days !
MMT
PostPosted: Tue Mar 13, 2018 8:35 pm    Post subject: Reply with quote
I do have headlamp washers. I will check that as I had the headlamps out to fit new bulbs recently.
Thank you.
GMG
PostPosted: Wed Mar 14, 2018 7:17 am    Post subject: Reply with quote
...suggest that you operate your washers to verify that the nozzles rise to wash the lenses...if not then it is possible that when you removed the headlight the washer connector was dislodged ?
Worth a check?
MMT
PostPosted: Wed Mar 14, 2018 8:17 pm    Post subject: Reply with quote
Mines a 996.1 with the old style nozzles. I will give them a spray and see if a pipes come off somewhere.
