997 : 2004- 87
996 : 1997-2005 43
Boxster : 1997- 14
Cayman : 2005- 14
Cayenne : 2003- 7
Macan : 2014- 0
Mike74
PostPosted: Tue Mar 06, 2018 10:31 am    Post subject: 997 Starting up Reply with quote
Hi guys,
I've recently obtained a 2007 997 Targa 4 manual, and it's got this intermittent issue on starting up. What happens is; foot on clutch, foot on brake, turn key, nothing but strange electronic buzzes and clicks. Repeat 4-5 times, and then the engine spring to life.
Doesn't happen all the time, just periodically. Had the car under snow for two days, and fired up immediately, but then later the same day, took 4-5 attempts to get it going.
Any ideas as to what might be causing this?
Cheers!
PostPosted: Tue Mar 06, 2018 10:38 am    Post subject: Reply with quote
It sounds like your battery is on the way out. You may want to change it before it fails completely. They don't give much warning.
Mike74
PostPosted: Tue Mar 06, 2018 11:11 am    Post subject: Reply with quote
OK, cool, thanks, much appreciated.
Tobyone
PostPosted: Tue Mar 06, 2018 11:17 am    Post subject: Reply with quote
Likewise I would say battery.
My Fiesta did the same
997.1 C4s GT Silver, factory Aerokit
James M-S
2009 Porsche 997 Carrera 2
PostPosted: Tue Mar 06, 2018 11:43 am    Post subject: Reply with quote
Are terminals secured?
PostPosted: Tue Mar 06, 2018 4:30 pm    Post subject: Reply with quote
I find it a little curious that for several attempts its like a flat battery but then spins over and starts the car .
Get the battery checked but im leaning towards a possible ignition lock or more likely the power distributor pin being corroded .
If it is that then its really a garage job but if you want to check then ..
Disconnect negative battery lead , undo battery clamp and slide the battery over to the o/s .
Follow the positive lead down to where it connects , the pin is under that , push the red tab downwards about 4 mm and the lead should slide back a bit to reveal the pin .
Dont pull it all the way off but just enough to see if its corroded .
Alternatively when the car wont start then wiggle that lead a bit and try and restart .
http://911uk.com/viewtopic.php?t=118716&highlight=power+dist
If you mean you just get a click from the engine each time you turn the key then its probably the startermotor .
PanozGTR
PostPosted: Tue Mar 06, 2018 6:44 pm    Post subject: Reply with quote
I had a similar problem a while ago on an BMW M3 and it turned out to be the ignition switch. If you turn the key and nothing happens , hold it over and wait to see if starts. The current can take a few seconds to jump across worn contactors.
2009 997.2 C2S Macadamia/Cocoa
Sold,
Audi B8 S4
Subaru WRX Impreza
BMW E30 M3
Alfa Sud
Mike74
PostPosted: Tue Mar 06, 2018 9:28 pm    Post subject: Reply with quote
Thanks for all the advice guys, much appreciated.
PostPosted: Tue Mar 06, 2018 11:36 pm    Post subject: Reply with quote
Mike, as Demort and others say, the 997 does have an issue seen it often reported with the ignition lock the symptoms are just as you describe . that would be where my £5 is on Thumb The gen2 has a similar issue but that on a micro switch under the clutch they did have a campaign at the OPC to fix the 997.2 issue but not the gen1 issue . Thumb
drmark
PostPosted: Tue Mar 13, 2018 7:42 pm    Post subject: Reply with quote
Faulty clutch switch (needs to be fully depressed for engine to start).
