997 : 2004- 74
996 : 1997-2005 46
993 : 1993-1998 6
964 : 1989-1993 5
Boxster : 1997- 15
Cayenne : 2003- 8
Macan : 2014- 3
912-914-924-928-944-968 4
cambjones
1997 Porsche 993 Carrera 4
PostPosted: Mon Feb 12, 2018 10:41 pm    Post subject: Reply with quote
Job done. As others have said it is quite easy, and saved £320 + labour.
It's probably an hour job if you know what you are doing, and 2 hours if you make a few mistakes along the way.
A couple of rookie mistakes for me, like jacking the car up before loosening the wheel nuts, and putting one side back together and realising I had forgotten to put the washer back on.
It's tricky getting the new rubber boot on, or rather getting the spring fastener back on.
Here are some photos in case others are planning on doing this. (pictures in reverse order)
The replacement rubber boot is a little taller (6mm) than the original ones but they seem to still do the trick as they are the correct diameter on the top and bottom. The original ones had what looks like a part number (020 060 015 012) on them but googling it does not help.
The completed job
 Filesize:  363.01 KB
 Viewed:  1184 Time(s)
Part number?
 Filesize:  368.9 KB
Getting the spring back on.
 Filesize:  1014.95 KB
half way through getting the spring on
 Filesize:  578.77 KB
The link with the boot and spring off
 Filesize:  387.29 KB
Getting the spring off
 Filesize:  670.78 KB
The cracked boot
 Filesize:  677.6 KB
17mm spanner
 Filesize:  687.02 KB
17mm spanner
 Filesize:  398.45 KB
 Filesize:  565.85 KB
cambjones
PostPosted: Mon Feb 12, 2018 10:48 pm    Post subject: Reply with quote
2 more pics
The original was 6mm shorter
 Filesize:  283.06 KB
 Viewed:  1177 Time(s)
Spring almost on
 Filesize:  260.87 KB
madalaa
2009 Porsche Boxster (987)
PostPosted: Tue Feb 13, 2018 10:06 am    Post subject: Reply with quote
Well done Cam, job well done Smile
cambjones
PostPosted: Wed Feb 14, 2018 8:44 am    Post subject: Reply with quote
Thanks mate. Nice to get my hands dirty. It's been a while since I've been 'under the bonnet'. Even the simplest job provides a great sense of self achievement 😁
kerb scraper
PostPosted: Wed Feb 14, 2018 5:53 pm    Post subject: Reply with quote
Well done. Always good to see a bit of DIY. Just out of curiosity : why did you refit the original circlip? Did the new boots not come with a large and small silicon rubber 'O' ring to fit?
1997 C4 Cabriolet, Arctic Silver, black interior, 18" hollow spokes, Bilstein PSS10s, RSRs, 200 cell cats, Mobil 1 sticker, LED to interior. Bergville t-lights.
cambjones
PostPosted: Wed Feb 14, 2018 6:08 pm    Post subject: Reply with quote
Ah I just assumed I had to replace the spring/clip... the new boots did come with silicon rubber 'O' rings to fit. They are on there as well...
So basically I guess I've upgraded Laughing
I'll be sure to remember that if ever I sell it...
I have the double secure drop link boots fitted.
Goto page Previous  1, 2
Page 2 of 2
