996 : 1997-2005 48
993 : 1993-1998 6
964 : 1989-1993 5
Boxster : 1997- 15
Cayman : 2005- 18
Cayenne : 2003- 7
Macan : 2014- 3
912-914-924-928-944-968 3
cambjones
1997 Porsche 993 Carrera 4
PostPosted: Wed Feb 07, 2018 3:15 pm    Post subject: MOT Fail - Anti-roll bar linkage ball joint dust cover Reply with quote
Another mark on my MOT history grrrrrrr....
The chap says this is a new item they need to inspect.
Nearside Front Anti-roll bar linkage ball joint dust cover excessively deteriorated so that it no longer prevents the ingress of dirt (2.4.G.2)
I reckon this is probably something I can do myself??
Anyone here done this before? Any tips?
I just can't seem to find this part easily though. All I seem to be able to find is the full link and not just the covers
https://www.porscheshop.co.uk/porsche-mechanical-parts/porsche-993-mechanical-parts-1994-to-1998/porsche-993-anti-roll-bars-drops-links-bushes-1994-to-1998/front-anti-roll-bar-drop-link-left-993-c4-c4s-turbo-1994-1998.html
I also can't seem to find the 'cover' or 'boot' on the parts diagram
https://www.deroure.com/diagrams.asp?MAK=3&MDL=24&TBL=2361&SMA=0&SMO=0&ST=99334307101&SC=1
Perhaps I do have to replace the full link?
Any help much appreciated
Sutton
PostPosted: Wed Feb 07, 2018 3:58 pm    Post subject: Reply with quote
https://www.elephantracing.com/porsche/993/swaybars-drop-links-for-993/#front-oem-replacement-drop-links
I see some rubber bushes but wasn't aware of a dust cover like the gaiters that cover driveshafts etc.
I took my old beater BMW for its MOT only to be told that there was excessive movement in the front offside bushes and deterioration of suspension components. We had a standoff when I produced the invoice for new dampers, springs, roll bars etc that had been fitted days before the MOT. His boss intervened and passed my car.
1994 993 C4
kerb scraper
I had exactly the same MOT fail. Porsche don't sell just the boot but you can buy generic versions easily from a good local motor factor for just a few pounds.
Fitting requires removal of the drop link but it is a very simple job requiring no special tools.
Rather rashly I bought two new drop links for mine to get back on the road quickly and then after inspecting the old ones repaired them with generic boots.
So now I have two good spare front drop links for a C4.
1997 C4 Cabriolet, Arctic Silver, black interior, 18" hollow spokes, Bilstein PSS10s, RSRs, 200 cell cats, Mobil 1 sticker, LED to interior. Bergville t-lights.
Sutton
PostPosted: Wed Feb 07, 2018 4:23 pm    Post subject: Reply with quote
Good catch kerb scraper!
Does the cover go over the whole bolt or does it sit between the drop link and roll bar?
1994 993 C4
cambjones
PostPosted: Wed Feb 07, 2018 4:24 pm    Post subject: Reply with quote
Many thanks.
Mine's a C4 also... this is what I could find by the way of a new drop link.
Is this what yours look like?
Which part is the boot? Are you able to show a picture of your old ones... or the boots?
I'm not sure what to ask for from the local garage for in terms of a generic boot.
 Filesize:  26.35 KB
 Viewed:  2895 Time(s)
cambjones
PostPosted: Wed Feb 07, 2018 4:27 pm    Post subject: Reply with quote
Ahhh... just saw your Link Sutton... thanks
That looks like the boot..
Is that right kerb scraper?
 Filesize:  180.42 KB
 Viewed:  2892 Time(s)
kerb scraper
PostPosted: Wed Feb 07, 2018 4:38 pm    Post subject: Reply with quote
The bit highlighted in the last pic is actually just a protective plastic moulding that comes on the new drop link to protect it in transit and is thrown away before fitting.
The boot that needs to be replaced can be clearly seen in your first pic as the transparent white bit with pink circlip holding it in place. I put up some pics with a separate post in 2016 but of course thanks to Photobucket policy change they have disappeared. I'll see if I can find them again in my archives.
cambjones
PostPosted: Wed Feb 07, 2018 4:59 pm    Post subject: Reply with quote
Thanks kerb scraper,
I phoned Porsche parts on the off chance they'd sell just the boot but no such luck.
New Drop links ~£200 each... ouch... when the piece of rubber probably costs £2.00
OK I'll hunt around and see what I can find
found this so far (in case other people are looking)
http://www.911uk.com/viewtopic.php?p=737131#737131
https://rennlist.com/forums/964-forum/733206-possible-to-replace-boots-on-oem-swaybar-links.html
Kat1
PostPosted: Wed Feb 07, 2018 5:23 pm    Post subject: Reply with quote
I had a similar issue on my C4 in June 17 - new link from Type 911 - £140 plus vat and shipping.
Wish I had known about the boot - that has really spoilt my day.
Sad
kerb scraper
PostPosted: Wed Feb 07, 2018 5:39 pm    Post subject: Reply with quote
OK here we go.
The generic boots that I bought were from my local factors Bennetts in St Albans (tel. 01727 855879) at £9.75 for a pack of five (you only need two). The manufacturer is 'High Tech parts' the product code is PRDC04 Dust Cover, hole 11x29mm height 26mm.
Picture of drop link showing damaged original boot (cause of MOT failure)
Generic boot and 'O' rings that replace the original circlip and seal in place:
Generic boot fitted:
I cleaned off all the old hardened grease first, cleaned and then packed the joint with fresh grease before fitting the new boot.
PM me if you get stuck, I may be able to help.
cambjones
PostPosted: Wed Feb 07, 2018 6:21 pm    Post subject: Reply with quote
Perfect!!! Thank you very much sir.!! worship
kerb scraper
PostPosted: Wed Feb 07, 2018 7:14 pm    Post subject: Reply with quote
Glad it was useful. If you are going to DIY then this other old post might be of interest: (obviously the last line of text now redundant)
http://www.911uk.com/viewtopic.php?p=994423#994423
cambjones
PostPosted: Wed Feb 07, 2018 8:33 pm    Post subject: Reply with quote
That's great, thank you for taking the time to dig up that old post.
I think I will have a crack at this myself.
wozy
PostPosted: Wed Feb 07, 2018 9:28 pm    Post subject: Reply with quote
New drop links £200 a piece ..... I paid £110 two years ago from my local OPC . Have they really gone up that much Dont know
Porsche Cars of Great Britain launched the 993 in the UK in early December 1993 registering 12 x UK cars on the 6th & 7th of that month; mine is one of them.
993 C2. MBM. C4 mounts, RSRs, RS Short shifter. RS steering wheel. FSDs & M033s
Previous 2.7S, 3.2, 964 and 968CS
cambjones
PostPosted: Wed Feb 07, 2018 10:42 pm    Post subject: Reply with quote
yeah local OPC quotes £160 something + VAT
Cheaper on Type911 £170 (£140 + VAT)
stucart
PostPosted: Thu Feb 08, 2018 3:25 am    Post subject: Reply with quote
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F182453907865
Just found these on EBay looks as if they’ll do the job.
997 C4S Tip-S, 2007, Silver/Red and Black Leather, PSE, Sports Chrono, Turbo wheels.
cambjones
PostPosted: Thu Feb 08, 2018 9:46 am    Post subject: Reply with quote
Unfortinately slighlt the wrong size.
These are the ones
Found them here. £12.53 for a 5 pack.
http://www.ebay.co.uk/itm/Prdc04-Pearl-Dust-Cover-11mmx29mm-Height-26mm-Pk5-PRDC04-Pearl-Quality-New/232415308018?epid=1443666355&hash=item361d0828f2:g:KDsAAOSwTApZbojb
The supplier is https://www.partsinmotion.co.uk/ and you can order from them direct also.
Bennetts do have them on the shelf for £9.75 but I have to drop into a store to pick them up which doesn't work for me.
There are other places you can find them online but they charge ~£9 for each one so you have to be careful.
Cameltoe & Heel
PostPosted: Fri Feb 09, 2018 9:29 am    Post subject: Reply with quote
I'm surprised they failed MOT on this, I think it's more of an advisory as there's no immediate safety issue.
So is the condition of the ball joint ok?, if so simply banging a new boot on makes lots of sense Thumb
Always nice to have a cheap fix now and again.
Trev
cambjones
PostPosted: Fri Feb 09, 2018 10:08 am    Post subject: Reply with quote
Yeah nice to have this.. probably save me £400k too...
Now... I get to spend £400 on something else Smile
I'm going to tackle it this weekend, I'll update how it goes.
PostPosted: Fri Feb 09, 2018 2:03 pm    Post subject: Reply with quote
You can get a mixture Here for £12.00.
I did this job last year and got a pair for c£4. Easy job Thumb
