PhilMorrison
- Joined
- 30 Apr 2013
- Messages
- 161
I'm selling an H&R ETS Lowering module I had fitted to the wifes Macan GTS for a couple of months.
It's in as new condition, and it simply plugs in in-between the ECU in the boot. It took about 15 minutes to install.
You can adjust the ride height front and rear with little dial screws on the electronic module. It's quite easy, and most importantly is easy to remove if you ever need warranty work done.
It fits all Macans with air suspension I believe.
H&R part number is 28804-1
Costs £1175. I'm selling for £900 inc UK delivery.
Here's a picture of it installed on our Macan GTS - This is with it set a lot lower than the recommended -35mm. This is no problem on the front, but the rear gets a bit crashy when set this low so I don't recommend it.
